Soft Transform
Soft TransformAuthor: Piotrek Marczak
AKA its full name Screen Space Proportional Object Transform. This tool works similarly to the built-in Proportional Transform Tool, but operates on objects instead of on points. Features as listed in the si-community thread:
TAB switches modes translate/rotate/scale (like in tweak tool) l/m/r mouse button for t/r/s (like in view space transform tool) .Rot. and scale is temporary, after releasing m/r button, tool switches to translate mode fcurve falloff from Move Proportional tool R hotkey for size change (like tweak tool) auto key handling for animation distance is measured to object's pivot point lock transformation to selected objects fancy buttons basic collisions (raw triangle mesh vs swept bounding sphere)
video demo / video demo (updated version) . Source available here. More details inside the si-community thread.
local backup: SoftTransform_x64_v11.xsiaddon
mjd3d
Re: Soft Transform
Post by mjd3d » 20 Jul 2012, 08:17
hi
There is a small problem in this plugin
If the Objects within the tree, the plugin is not able to put the keyframes of the Objects when moving
thanx
Re: Soft Transform
Post by origin » 10 Aug 2012, 17:11
mjd3d wrote:hi
thanx
Hi, I fixed this bug and added falloff bias to the brush (like tweak tool, shift+r). Updated first post with new version.
Memag
Re: Soft Transform
Post by Memag » 10 Aug 2012, 18:21
Re: Soft Transform
Post by origin » 10 Aug 2012, 18:38
yep 64 bit only
mjd3d
Re: Soft Transform
Post by mjd3d » 11 Aug 2012, 09:09
Thanx For Fix. :)
Boris
Re: Soft Transform
Post by Boris » 15 Aug 2012, 06:33
how possible make to open tool through hotkey!? :-bd
Oops ,something went wrong :D
Re: Soft Transform
Post by origin » 15 Aug 2012, 06:35
keyboard mapping->custom script commands
Boris
Re: Soft Transform
Post by Boris » 15 Aug 2012, 06:45
origin wrote:keyboard mapping->custom script commands
thank you ! :)
Boris
Re: Soft Transform
Post by Boris » 15 Aug 2012, 06:53
Origin ! Please !!!! do so this tool could work with animation layers, or shapes manage! PLease ! and if possible to do so work with clusters point ! Thank you very much ! you good Man ! :-bd :ymhug:
Toonafish
Re: Soft Transform
Post by Toonafish » 12 Oct 2012, 10:48
wow, great plugin ! Thanks a big bunch for sharing this little gem !
