IRay Progressive Rendering Tests
Kzin
Re: IRay Progressive Rendering Tests
Post by Kzin » 15 Jan 2013, 08:16
its ok for what it does, but in general to slow. with this rendertime i expect a noisefree solution.
cuanyo
Post by cuanyo » 17 Jan 2013, 03:48
I always use ctrl_ghost_setting with gtx460 in my softimage2012 and it's really useful for me.
until that I've changed my card to gtx660 and update to 2013, it's just can't work anymore.....
but gtx460+si2013 still can render with iray.
so sad...
here is error message:
# ERROR : IRAY 0.4      8 MB error: CUDA device 0: "GeForce GTX 660" (compute capability 3.0): unsupported by this version iray, please look for an update with your software provider.
# WARNING : IRAY 0.4     34 MB warn : no CUDA capable devices found
but same ver of libiray.dll and libiraymr.dll still working in max 2013.
sorry for my poor english.
Kzin
Post by Kzin » 17 Jan 2013, 07:12
because the kepler cards are supported later and your 660 is one.
iray3 will have support for it, iray 2.x got support with an update, but we dont got a updated xsi version with updated mr since a long time.
write a mail to ad that you as a customer wants more softwareupdates between the versions. 2013 is a completely fail in that area.
cuanyo
Post by cuanyo » 17 Jan 2013, 08:48
sorry,
I've put files to wrong dir.
when I change to a right dir, I got new error code:
# WARNING : LIB  0.4      8 MB warn   292015: loading C:\Program Files\Autodesk\Softimage 2013 SP1\Application\bin\nt-x86-64\libiray.dll: §ä¤£¨ì«ü©wªº¼Ò²Õ¡C
# ERROR : IRAY 0.4      8 MB error  841098: failed loading iray rendering plugin C:\Program Files\Autodesk\Softimage 2013 SP1\Application\bin\nt-x86-64\libiray.dll
libiray.dll and libiraymr.dll are copy from 3ds max 2013 update 6 , it's mental ray 3.10, same with si2013,
3ds 2013 can render with iray, but si2013 can't do that.....
maybe autodesk made a some protect for iray render in this time...
Kzin
Post by Kzin » 17 Jan 2013, 08:59
cuanyo wrote:sorry,
then you used the dll from max update 6 then you used files from an more actual iray version i think. maya and max mr version were updated while xsi's mr version was not updated.
hardgore
Post by hardgore » 21 Jan 2013, 17:53
is the iray faster than arnold? =p~
i have gtx460 1g
Post by Maximus » 22 Jan 2013, 12:18
hardgore wrote:is the iray faster than arnold? =p~
i have gtx460 1g
Not remotely
