Hello gaboraa,
It looks like it is a bug, but not on the Cap borders side.
When you apply this compound using the right click menu, it will call the "ApplyICEOp" command to add a new ICETree on your object with the Cap Borders compound.
Unfortunately, it looks like when using this command it doesn't update the UVs correctly. So for now, the workaround is to apply the compound manually using the ICETree view.
Thanks for your feedback,
Guillaume
ICE Modeling Workshop 2: Cut edges
gaboraa
Re: ICE Modeling Workshop 2: Cut edges
Thanks! I could manage to do it with manual way as you said and it is good to hear that there will be an update on this issue. And of course I will post further bugs if there will be any.
BTW Apply thickness rules! There are wonderful options in there which make it extremely useful.
