Post by wireframex » 08 May 2019, 19:41
@Shekn :
I tried HDRMaster but I saw it doesn't cast shadow at all. Could you tell me if it's normal or not ?
I suppose the best way is to use SkyTexture.
Phil
Post by Shekn » 09 May 2019, 17:16
HDRMaster is actually only a preset for using hdr-maps as environment light. When background light is created, it does not link to any hdr-map. In this case this map is solid white. The render result in the first picture. But when I select any hdr-map from the library, then this map start using as background light source. The render on the second picture. If the hdr-map contains contrast sun, then there is visible shadow on the render. If the hdr-map is not contrast, then it looks like soft ambient light.
Post by wireframex » 09 May 2019, 18:38
Thanks a lot :)
i.m.p
Post by i.m.p » 31 May 2019, 23:33
I'm having issues when using alpha/opacity maps. Can you show me the proper nodal setup when using the cycmixclosure and transparent bsdf shader ?
Post by Shekn » 01 Jun 2019, 05:23
Here the screen with typical setup:
viewtopic.php?p=61380#p61380
If you have some problems or something works wrong - post here the screenshot with your shader tree and render result.
i.m.p
Post by i.m.p » 01 Jun 2019, 20:42
Thanks for the input. I also found this to be quite helpful:
https://www.cgbookcase.com/textures/how ... in-blender
sirdavid32
Post by sirdavid32 » 03 Jun 2019, 16:48
This is so frikken cool! I feel I am not waisting my time with Blender, since I can also jump and work with the same shader tree from blender to softimage.
You know what this marvelous Sycles is missing? a GUI export/import of .blend cycles materials.
But I guess that´s a lot of intertwained .dlls to tweak on softimage side to "open" a .blend and navigate to their "materials" folder and pickup whatever shadertree it needs. :)
But hey... who knows? :)
I ask of this because of online render farms. If there was only a chance to tell old Online render farms who previously supported Softimage, that they can use this open source SYCLES materials and render engines, we would wake up some renders even faster.
Right now, as it is, Sycles speed is limited by the amount of Vram and Cores your actual system has.
If you want a speedier setup, there´s no renderfarm because of EOL.
Post by Shekn » 04 Jun 2019, 07:07
You can import material from Blender to Softimage by using this addon: https://ssoftadd.github.io/gesPage.html
But not from Softimage to Blender, because this direction in future plans.
sirdavid32
Post by sirdavid32 » 01 Jul 2019, 18:08
Awesome! Thank you!
yashugan
Post by yashugan » 08 Jul 2019, 06:40
Hi, i have found a bug, can i write in private or i describe it here? :)
Post by Shekn » 08 Jul 2019, 09:47
Write me to PM.
Post by Shekn » 20 Jul 2019, 16:42
Small update. Version 1.7.8, download here: https://ssoftadd.github.io/download/Syc ... 8.xsiaddon
Update contains realization of two small feature requests:
1. Add additional formats for output of a rendered images. Now render result can be saved in the following ldr formats: png, bmp, tga, sgi, iff, jpg, jp2, ppm, and following hdr formats: tiff, exr, dpx, fits, hdr, rla, pfm.
2. Add support for rendering image sequences as textures. ImageTexture and EnvironmentTexture nodes contains additional parameter "Image Source". If this parameter is equal to "Single Image", then the render engine use selected texture. But if this parameter is equal to "Image Sequence", then some additional parameters appear, and render engine use different texture for different frames. File for selected texture should have the name similar to "someTexture_1.png" or "someTexture.1.png". It's important that there is a section at the end of the name with a number, and this section separated by "." or "_". Then this number will be replaced by frame number.
Post by wireframex » 20 Jul 2019, 17:55
Thanks a lot :)
Post by wireframex » 30 Jul 2019, 15:51
Open Image Denoise V1.0
Changes in v1.0.0:
- Improved denoising quality
- More details preserved
- Less artifacts (e.g. noisy spots, color bleeding with albedo/normal)
- Added maxMemoryMB filter parameter for limiting the maximum memory consumption regardless of the image resolution, potentially at the cost of lower denoising speed. This is internally implemented by denoising the image in tiles
- Significantly reduced memory consumption (but slightly lower performance) for high resolutions (> 2K) by default: limited to about 6 GB
- Added alignment and overlap filter parameters that can be queried for manual tiled denoising
- Added verbose device parameter for setting the verbosity of the console output, and disabled all console output by default-
- Fixed crash for zero-sized images
Post by Shekn » 19 Aug 2019, 17:10
Update 1.8. Download here: https://ssoftadd.github.io/download/Sycles_1.8.xsiaddon
What's new:
1. Compiled with the latest version of the Cycles. So, now Sycles contains all bugfixes and improvements of the original Cycles.
2. Area lights now supports elliptic shapes.
3. All lights contains parameter "power", which allows to change light intensity without changing shader parameters. In particular, it allows to use several lights with different intensity but with the common shader.
4. Two new nodes for the shader tree: Map Range and Clamp.
5. Output Cryptomatte passes. How to use - tutorial 30 in the manual.
Post by wireframex » 19 Aug 2019, 17:36
Thanks a lot Shekn :)
Tell me what do you think about e-cycles https://evermotion.org/articles/show/11 ... in-blender ?
