GoSoftimageLite - Zbrush-Softimage exchange [UPDATE!!!!]
Nizar
Re: GoSoftimageLite - Zbrush-Softimage exchange [UPDATE!!!!]
Thanks jester
I tried delete obj file, and no, don't work, XSI doing the some. Now I try uninstall.
Nizar
No, the some issues ....
zossowosso
hi
here too I have the same errors
a) ok
b) ok
don't work...
It is all correct (folder and all setting), but when I try to import mesh from zbrush I receive the message "GoSoftLite file don't exist!", and when try to export, compare a red message "can't create output file"
If I go in gosoftlitedata folder, I find the correct obj file created by zbrush (and can import in softimage)
It is strange it worked correctly and, after a crash with heavy mesh it don't work...
Folder path is:
c:\Program File (x86)\Pixologic\Zbrush 4.0\ZStartup\ZPlugs\GoSoftLiteData This is the correct folder, and this is the folder I wrote in Softimage|preference|Custom|GosoftliteSettings
In this folder Zbrush create the correct GosoftLite.OBJ (and .mtl) file
my mistake was the name of the file
C:\Program Files (x86)\Pixologic\ZBrush 4.0\ZStartup\ZPlugs\GoSoftLiteDataFolder
C:\Program Files (x86)\Pixologic\ZBrush 4.0\ZStartup\ZPlugs\GoSoftLiteData this is the proper name......I know
may be that your problem Nizar
now it`s working like a charm
thanks j3st3r nice job
-we read too fast
-copy and paste too fast
-In any case, It was my mistake
Actually GoZ and GoSoftimageLite is not for heavy meshes...I used to transfer at most 10-20k polygons, with no issue. You need to check the following stuffs:
a) In your ZBrush/ZStartup/ZPlugs folder there must be a GoSoftLiteData folder
b) In your Softimage File|Preferences|Custom there must be a GoSoftLitSetting pointing to your Zbrush root folder
If the above mentioned things are OK, GoSoftLite should work.
Now I try to solve multiple subtool exporting on the lowest level, it may take a while...
a) ok
b) ok
don't work...
Folder path is:
-we read too fast
'ERROR : 2011 - Unable to write well in English [CLSID\{F123FC55-ABD9-4D7F-9CDD-7F9D61E71FFE}] : %SUMATRAPATH%\ English.dll not found'
Nizar
Hi Zossowosso
no, my folder is exact... I'm little embarrassed about, I'm sure it is a stupid error, but don't find where is... and cannot understood why the first time worked fine and after the XSI crash (with a heavy mesh XSI import) don't work.
zossowosso
hi Nizar
are you sur to use the right GoSoftLite.zsc if yes
I suggest you
uninstall the plug in softimage and delete the GoSoftimageLiteAddon foder in you user group or workgroup
delete the GoSoftLite.zsc in Zbrush folder
and start a new installation
may be ???
I suggest you
may be ???
Nizar
Hi, thanks Zossowosso.
I cancelled and unistall from zbrush and from XSI, repeat all the operation, and now work. But if I try a heavy mesh, XSI crash and stop working (for all the mesh, I must cancel again all and reinstall).
j3st3r
Zbrush works well without error messages?
j3st3r
What is heavy mesh? How much polygons? Actually it uses the builtin OBJ importer, so you may try to import it via the Import OBJ menu in the File menu
Nizar
mesh is 2.000.000 polygons. It is only a test, actually don't need. If I import like obj it work correctly (xsi can manage it)
No, zbrush don't give any error message
j3st3r
I'll check it. But the fact is that I call the ObjImport function which is the same as if you just use the File|Import|OBJ menu...
zossowosso
Nizar wrote:mesh is 2.000.000 polygons. It is only a test, actually don't need. If I import like obj it work correctly (xsi can manage it)
hi Nizar
for fun export from Zbrush your mesh 2.000.000 polygons normally in obj format and re-import the mesh in obj format in SI to see
Nizar
It work correctly, only if I use GoSoftlite had problem. I don't know why
j3st3r
As a last try. please zip the GoSoft addon folde, and send me to check. I need just the addon you insalled
Nizar
Hi, thanks so much
Do you mean the folder in XSI directory? Can attached file in a simple PM?
j3st3r
Nizar
Cannot send message (site maintenance). this is my folder, you can download from this link http://www.mediafire.com/?6hjhz6xg7ewrgq6
