XSI Theme for Blender 2.83 - (May release)
sirdavid32
Re: XSI Theme for Blender 2.83 - (May release)
Post by sirdavid32 » 03 May 2020, 19:33
All right team! XSI theme for Blender is out and ready for download! If you're a Blender user, support the thread here: https://blenderartists.org/t/xsi-theme- ... 20/1220169
I hope this can get renamed to SOFTIMAGE. I don't see a problem with that since they have names like MAYA and MODO out in the open for themes.
sirdavid32
Post by sirdavid32 » 03 May 2020, 19:34
Check out the complete FULL POST here: https://wp.me/p4qGvb-ox
Lots of pictures and detail comparisons on what I've done with the theme.
Grims
Post by Grims » 04 May 2020, 11:07
Great job man!
I'm already using it :D
The Future is Gloomy!
Post by Bullit » 04 May 2020, 11:07
What are the compatibility with industry key maps? and did you got one similar to XSI?
sirdavid32
Post by sirdavid32 » 05 May 2020, 06:19
Keys that are hard coded and cannot be changed: U,S,G,R,X,Y,Z everything else could be custom key assigned.
Post by Bullit » 05 May 2020, 16:37
ok, thanks
Grubber
Post by Grubber » 14 Jun 2020, 22:12
Hello,
Started learning blender, and the theme is great!
Just wondering if there is a way to set a color for open edges in Blender.
Thank you in advance.
sirdavid32
Post by sirdavid32 » 15 Jun 2020, 21:07
Hey Grubber, glad you're trying out Blender. If there are any questions, I am happy to answer them for you.
About the OPEN EDGES, yes, you may go into EDIT>PReferences>themes>3DViewport> Then search for EDGE ....xxx....
Like:
EDGE SELECT
EDGE SEAM
EDGE SHARP
...etc..
If there are floating or "open" edges, (floating vertices) you can use: F3 (search) or Spacebar (search) while in edit mode, and type "merge by distance", a small pop up will appear on your lower left side of the viewport, where you can adjust the range to merge edges or vertex. When you're done, press ENTER. A notification on the bottom of the screen will tell you how many vertices were merged. You can click on the notif to pop up a window and read the message clearer.
Post by FXDude » 17 Jun 2020, 19:41
Huh! , I didn't know there was open edge visibility
thanks for the tip!
Grubber
Post by Grubber » 18 Jun 2020, 10:50
sirdavid32 wrote: 15 Jun 2020, 21:07 Hey Grubber, glad you're trying out Blender. If there are any questions, I am happy to answer them for you.
Like:
EDGE SELECT
EDGE SEAM
EDGE SHARP
...etc..
Thank you. Unfortunately, I can't find any option to adjust open edge color. I am using 2.83 version.
Post by FXDude » 18 Jun 2020, 19:27
I don't think there is open edge viz, (or maybe there is now I dont know..)
But to visualize open edges, you can also do -select all-,
and do ... Select > Boundary Loop
