Create Grass
Create GrassAuthor: Nassos Yiannopoulos
Makes strands on a given surface that are curvy to look like grass blades. The zip contains a shader preset for the grass; copy it to your »DSPresets/Shaders/Material« folder
Related plugins: New Grass
local backup: Create Grass v1.1.rar
nassosy
Re: Create Grass
Post by nassosy » 14 May 2010, 23:23
here is the 2011 scene
Re: Create Grass
Post by Maximus » 14 May 2010, 23:54
i downloaded your scene and the problem is there too, you gotta activate final gather, thats what i did with your scene, set gamma 2.2 in exposure shader and f-stop at 8 to see better.
it seems it has some problem with FG?
i'm uploading my scene in a moment
nassosy
Re: Create Grass
Post by nassosy » 15 May 2010, 11:50
The problem seems to be with the grass normals looking on the wrong side :
' WARNING : RCFG 0.6 warn 542002: angle between normal and geometry normal > 90 degrees
the only solution i found is setting the Mode to "Expert"
and the "Filter Size = 0"
Re: Create Grass
Post by Maximus » 15 May 2010, 13:38
oh thats fine, i use expert with 0 0 quite often for exteriors, so it should work :)
i'll check it in a bit
Re: Create Grass
Post by Maximus » 13 Jun 2010, 19:33
viewtopic.php?f=25&t=752
used for the grass here,thanks again for this awesome compound, i had so much fun :D
nassosy
Re: Create Grass
Post by nassosy » 17 Jun 2010, 10:58
Here is a sample for those having difficulties.
Ramon
Re: Create Grass
Post by Ramon » 22 Oct 2010, 08:54
SI 2011 AP 64 bit
when load compoud error
// WARNING : 3000-EDIT-AddICECompoundNode - Could not set value on [Randomize Around Value 0].Variance
// WARNING : 3000-EDIT-AddICECompoundNode - Could not set value on [Randomize Around Value 3].Variance
// WARNING : 3000-EDIT-AddICECompoundNode - Could not set value on [Randomize Around Value 14].Variance
// WARNING : 3000-EDIT-AddICECompoundNode - Could not set value on [Randomize Around Value 16].Variance
// WARNING : 3000-EDIT-AddICECompoundNode - Could not set value on [Randomize Around Value 17].Variance
not work bend and rand angle
ok reconnect node bend strands after self strand size and color and it work! strange
julius
Re: Create Grass
Post by julius » 27 Oct 2010, 13:32
did anyone try to create animated grass with this compound?
joquer
Re: Create Grass
Post by joquer » 25 Jan 2011, 19:00
When I set the Attribute_Color to StrandColor it is not bend, but when it is set to Color, The blades are bended. I do not understant why tweaking the render_tree changes the shape of the blades?
I tried to reconnect the node bend strands before self strand size and color, as it was connected after, and I have bended blades again but no more color.
I am using Softimage 9.5 64 bit (2011 Subscription Advantage...)
JoQ
Loki
Re: Create Grass
Post by Loki » 22 Jun 2011, 11:38
Hallo
Anyone knows how can I use a texture to color the grass made with this compound?
(sorry for my english)
Re: Create Grass
Post by Hirazi Blue » 22 Jun 2011, 13:57
Do you mean texturing individual strands along their length? :-?
Ramon
Re: Create Grass
Post by Ramon » 05 Jul 2011, 11:07
NOT work in SI 2012 SP1
what wrong in strands compound? what change from 2011?
Re: Create Grass
Post by rray » 05 Jul 2011, 12:23
The new (V1.1) Randomize around Value compound has a Scalar node in place of V1.0's pass_through node, letting it not accept arrays or vectors as inputs anymore.
Go into the compound and switch all Randomize around Value compound versions back to 1.0, then it should work as usual.
Probably a bug introduced in 2011SAP, since the "Variance" parameter is also named "Value1" in the compound, which is unusal for factory compounds.
mirkoj
Skype: mirko-jankovic
Re: Create Grass
Post by mirkoj » 22 Aug 2011, 06:55
Hey I'm having small problem with this :)
Sample scene works perfectly in SI2012. everything as it should be.
But when I try to create my own grid with grass, Create Grass compound is always red.
Am I mising something or?
Again, imported sample scene works fine.
Any ideas?
Ramon
Re: Create Grass
Post by Ramon » 22 Aug 2011, 07:01
You must change some nodes in compound! see post above!
mirkoj
Re: Create Grass
Post by mirkoj » 22 Aug 2011, 08:12
ugh. mental note, read read read before post.
sorry got it!
unfortunately there is a huge amount of grass needed and ram goes over the roof!
my 8gb is not nearly enough and fur goes a bit under that so I will probably have to settle with fur :(
but thanks!
