PolyMesh Duplicator v1.2.1
PolyMesh DuplicatorAuthor: Nassos Yiannopoulos
V1.2.1 Nassos' recreation of Guillaume Laforge's addon (see video). Creates multiple procedural copies of a mesh which can be accessed from an ICE tree. Just like Houdini's Copy/Duplicate SOP. See video tutorial on vimeo, and for more details see the si-community discussion link.
local backup: PolyMeshDuplicator1.2.1.zip
nassosy
Re: PolyMesh Duplicator v1.1
Post by nassosy » 12 Nov 2009, 20:41
And BTW,
my apologies for the messy C++ source.
Post by Maximus » 12 Nov 2009, 22:40
i dont understand how this work...
i have SI 2010 x64 SP1
Following your vimeo tutorial.
After install i open a new fresh scene, create cube -> Polygon MEsh - > polymesh duplicator, then i get an error wich is this:
' VERBOSE : ApplyPolyMeshDuplicator_Execute called
' ERROR : 2028-EDIT-AddICECompoundNode - Invalid argument specified. - [line 97 in C:\Users\Max\Autodesk\Softimage_2010_SP1\Addons\PolyMeshDuplicator\Application\Plugins\ApplyPolyMeshDuplicator.vbs]
' ERROR : 2028-CUST-ApplyPolyMeshDuplicator - Invalid argument specified.
Then i check the explorer, and i found Cube and cube_copies wich has "PolyMeshDuplicator" under modeling construction mode. I click that open it up and change the values from 1 to anything else and they dont duplicate, nothing happens.
No idea whats wrong.. i installed the last one you posted, this one:
PolyMeshDuplicator Addon v1.2.1.rar [61.33 KiB]
Can help me please ? :D
Thanks a lot for your patience
Squizmek
Skype: squizmek
Post by Squizmek » 12 Nov 2009, 23:45
Maximus wrote: ' VERBOSE : ApplyPolyMeshDuplicator_Execute called
Restart XSI after installing the Addon. Then it will find the new compounds.
Post by Maximus » 13 Nov 2009, 08:11
did that, i do the same thing as before and nothing happens
No idea whats wrong :(
nassosy
Post by nassosy » 13 Nov 2009, 09:28
when changing the scripts i "cut & pasted" instead of "copying & pasting" some parts
my mistake. x_x :-s :(
redownload from here please
Post by Maximus » 13 Nov 2009, 12:17
thanks!!!! works perfect! :)
Post by wireframex » 14 Nov 2009, 00:37
Hi
I can't install this script maybe it is not compatible with 7.01 x64 ?
Phil
nassosy
Post by nassosy » 14 Nov 2009, 01:06
What do you mean you can't install?
Does it give you an error?
Does it's icon in the Plugin Manager have a red triangle?
Does it install and does nothing?
Does it crash 7.01?
What??? :-??
Post by wireframex » 14 Nov 2009, 10:40
Sorry,
There is the message from XSI :
The plugin is not compatible with the current platform ...
PolymeshDuplicator installed from Install Add-On menu
XSI 7.01 x64
windows 7 Ultimate x64
RAM 8 Go
Phil
nassosy
Post by nassosy » 14 Nov 2009, 11:13
This is weird, since i compiled it with the 7.01 x64 libraries.
on my winxp 64 machine it works fine.
I repacked the addon from inside 7.01 x64
if it still doesn't work
i rar'ed the folder structure of the addon
so just decompress it in your "Addons"
user directory under the name "PolyMeshDuplicator"
and either restart XSI or manually load it.
Post by wireframex » 14 Nov 2009, 11:51
Thanks a lot for your super fast answer.
well same pb here for the 2 solutions :
I have this message :
ERROR : 2360 - This plug-in is not compatible with the current platform and will be ignored:
<path: C:\Users\xxxxxxxx\Softimage\XSI_7.01\Addons\PolyMeshDuplicator\Application\Plugins\PolyMeshDuplicator.x86.dll>
seems it only wants a x64 dll ?
Phil
nassosy
Post by nassosy » 14 Nov 2009, 11:56
the x86 version is not supposed to be compatible with the x64 edition
it is for 32bit XSI.
It should automatically ignore it
well just delete the "PolymeshDuplicator.x86.dll" file
and leave the "PolymeshDuplicator.x64.dll"
Post by wireframex » 14 Nov 2009, 12:02
Now it works ^:)^
Thanks a lot
Phil
EDIT : Maybe you need to try to detect typical version of XSI because PolymeshDuplicator.xsiaddon doesn't install for me because of the x32.dll
EDIT2 : Or just do 2 versions of your script x32 and x64
nassosy
Post by nassosy » 14 Nov 2009, 12:36
Didn't install or didn't load?
Because if it didn't install you wouldn't get the following error:
which is ok BTW.
XSI is supposed to ignore one of the two ".dll"s and continue loading the other one.
Correct me if i am wrong, but i have the suspicion that you didn't even try the command
after the error msg appeared.
Do the following :
Uninstall the addon,
re-install it,
the error msg will appear (as expected)
create a cube (or whatever primitive)
try the "Modify->Poly. Mesh->PolyMesh Duplicator" command
and tell me if it works.
Post by wireframex » 14 Nov 2009, 12:48
In fact it did'nt works at all, if I want to use it it tells me :
Unspecified failure
nassosy
Post by nassosy » 14 Nov 2009, 12:53
could you post the whole line of the error?
it usually prints the line number of the file where it encountered the error
