How to make ICE Strand get to it's full length gradually
Pancho
Re: How to make ICE Strand get to it's full length gradually
Post by Pancho » 05 Feb 2013, 14:56
you need a linear interpolate node and interpolate between array before deform and array after deform (initial strand position). strand position > get array size = total entries. For position in array you would need to find another way. Not sitting in front of ICE currently, but you could dig into some fur tutorials/compounds from Kristinka or Melena and try to find the ones for clumping. There's a way to change the amount based on the position in the array. Try to dig into ICE a bit to get a more solid understanding how it works. It's pretty amazing what's possible.
Helli
Post by Helli » 05 Feb 2013, 15:00
Use the attached compound.
Get a 3d vector node and a multiply by scalar and multiply the vector with the output of that compound and feed it into the variance input.
With the strand fcurve compound you can do something along a strand.
Caveman
Post by Caveman » 05 Feb 2013, 16:28
Hi Helli for some reason StrandRatio truns red.
Hi Pancho Linear Interpolate works, but for the whole strand, as you have implied.
Pancho
Post by Pancho » 05 Feb 2013, 16:38
Discect the compounds from the hair solutions as I told you. You can learn a lot by doing this and find the solution how to "mask" certain areas. : )
Helli
Post by Helli » 05 Feb 2013, 18:55
Oh sorry then, then thats set in a Melena compound on emit thought this is a standart attribute.
Caveman
Post by Caveman » 06 Feb 2013, 06:59
Hey no problem. I myself am experimenting as well, so no harm in testing and failing. Btw StrandRatio is a standard attribute. Maybe I am doing something wrong. This is what I did with your compound.
3d Vector ---> Value Port of Multiply by Scalar
Result ---> Variance port of Turbulize
Your compound ---> Factor port of Multiply by Scalar
Helli
Post by Helli » 06 Feb 2013, 09:01
Hey there
I attached another compound.
After you created your strands you need to set your strandRatio, then you can use the strandFcurve node too,
This compound only calculates a new value for each strandposition between zero and 1 by dividing the actual point index of a strand through the total number of points on a strand.
Caveman
Post by Caveman » 06 Feb 2013, 10:08
Helli. It works great :ymparty: .
Helli
Post by Helli » 06 Feb 2013, 10:24
But don't forget to look into the compounds and find out how they work :)
Caveman
Post by Caveman » 06 Feb 2013, 15:03
I will heed your advice. Thanks :)
