Got it!
[thanks to Steve]
First thing I did was try writing the toxik.ini file.....nope Composite still crashes.
So, from the command prompt, I know this works:
set ADSK_COMPOSITE_LICENSE=SOFTIMAGE
C:\Program Files\Autodesk\Softimage 2013 SP1\bin\setenv.bat
composite
So then I tried:
composite
..and that still crashed...so I knew it wasnt the ASDK_COMPOSITE_LICENSE
So then I figured it was something that the setenv.bat is setting...turns out its SI_HOME.
So now this worked from the command line...
set SI_HOME=C:\Program Files\Autodesk\Softimage 2013 SP1
composite
So, for a permanent solution, all I ended up doing was adding SI_HOME as an environment variable and I'm back in business. No more crashes and I can run Composite by double-clicking the icon from the desktop.
Hope this helps other out there.
