Texture Instancing Compound
Texture instancing Shader V1.5Author: Reinhard Claus
Updated April 2013 with the ability to fetch the texture offset from an ICE attribute. Previous update added texturable scale X/Y.
The basic function of this shader is to stamp an instance of the selected texture at each particle location on the shaded object.
The shader requires an ICE particle cloud as a texture placing source which has to have its material shared with the object. It has features such as: Modify texture base scaling and rotation, various lookup options for fractal-like patterns, random position offset in texture, rotation by ICE particle vector attribute, random rotation, orient towards a vector or a tangent map. Mental ray only. See the si-community thread for some interesting looking renders created by Rob Chapman.
Mad props to Paul Smith aka pooby for inventing this wonderful method. If you haven't already, check his videos page for loads of ICE inspiration. Btw Paul's first video introducing the method is here. Btw #2: Since, he's created two videos demonstrating this shader: Texture Instancing Shader (archive) and Lizard texinstancing (archive).
local backup: Texture Instancing.1.5.xsirtcompound
Re: Texture Instancing Compound
Post by rray » 01 Aug 2012, 11:20
In that case, here's it. Writes random values to the scale attribute in ICE, reads it back in the render tree.
druitre
Post by druitre » 01 Aug 2012, 12:10
Aah, I got it: it was down to the max points/max distance in the map lookup settings. Weird, I thought I had that covered in yesterday's variations.
Thanks for the example!
Post by rray » 01 Aug 2012, 13:14
Hey great. "1" for max points outputs 1 attribute per texture/point. Setting it to more than 1 averages the attribute values. Can lead to some interesting effects sometimes.
druitre
Post by druitre » 06 Aug 2012, 18:21
Hi Ray, me again! Solved one issue, stumbled onto the next :)
How does one go about using this technique on an enveloped mesh? I managed to figure out some ways to control pointscale and texturescale and combined with flow along curves this gives me a good starting point for creating skin/scales/pores etc on animals/humans. But, if I animate my character, the texture does not stay locked on the deforming mesh.
For pointposition, I can only get that locked by setting emissiontype to 'point', disabling 'time varying' and deleting 'relax particles'. Which also means I lose an even/relaxed distribution. If I leave 'relax particles' in place, it looks like it is evaluating the relax-parameters after the deform, not before it. Even though the ICEtree is in the modelingstack?
Scale on the other hand, when I randomize that by adding a turbulize around value, looks like it is using global coordinates - the randomization stays in place with the mesh moving through it.
Everything I've been trying so far hasn't taken me any closer to a solution. I figure it must be possible though. Mapping to UV coordinates? Or setting up a (non-deforming) copy of the mesh and using that as input in a second tree?
Ofcourse, I could rendermap the texture to a UV at first frame, but it would be way cooler to keep the whole thing live.
Any suggestions welcome!
Post by rray » 06 Aug 2012, 21:47
There are some approaches that might do it like freezing the PC, then sticking the particles to the mesh, or maybe enveloping the point cloud so it deforms along with the body. You'd have to link the rotation lookup parameter to the particle rotation somehow in either case. TBH I think out of lazyness I would go with rendermapping for that one (Sound unadventurous I know x_x )
Pooby
Post by Pooby » 02 Jan 2013, 14:51
I had a proper go with this shader, and I have to say, its brilliant. Thanks for making it.
I've been fiddling around with it all morning doing trees and all sorts with ease. If I had one request it would be to be able to control the parameters of each sample with a weight map. so, say you were doing a tree, you could make the texture finer and less intense on small branches, but you can kind of do that now by mixing 2 shaders.
I did a video overview of the use of it.
Edited by gustavoeb: use vim tag :smile:
Post by rray » 02 Jan 2013, 23:37
Chuffed to see! Keep up your tutorials too they are great.
Pooby wrote:If I had one request it would be to be able to control the parameters of each sample with a weight map. so, say you were doing a tree, you could make the texture finer and less intense on small branches
The shader is completely build out of factory nodes, to use a weightmap to control some parts of it like the texture scale or offset, you can edit the compound and expose these parameters for texturing. But for blending two textures the only option is probably using 2 shaders like you did.
This scene shows how to use another ice parameter on the point cloud that is controling the scale: DemoProjectTextureInstancing3.zip.
Post by rray » 04 Jan 2013, 20:33
Updated ..... This new version can break up the cell borders.
Btw, for rendermapping is there an aliasing setting somewhere like in the render options ?
or is the supersampling the only option to increase quality?
Download is on first page
Pooby
Post by Pooby » 04 Jan 2013, 22:01
Great thanks. I look forward to trying that out. I find it amazing how the borders don't notice much, as in this example showing the scaling by weightmap, that I didnt intially think was possible, but is...
https://vimeo.com/56762083
But having a way of blurring them borders will be even better.
Post by rray » 04 Jan 2013, 22:33
Oh that worked really well.
I didn't think it would because I was texturing the scale of the cell shader a while ago, and that produced weird smearing along the gradients. Never tried it with the texture instance shader for that reason.
Post by rray » 07 Jan 2013, 12:29
Updated .. V1.4 allows separate X and Y scaling, also added a few comments in the compound so it's easier to get into the inner workings
(an earlier 1.3 update had X & Y scaling too, but had some problems with shearing effects when rotating stretched textures)
kykeon
Post by kykeon » 22 Jan 2013, 18:00
Hi there,
first of all, what a nice tool we have there! Many thanks to Reinhard Claus.
My question is about using the texture's alpha to avoid "square" overlapping. I would like to make a snake skin, and the look has to be very regular obviously...
Does anyone achieve to use the alpha, or did I miss something somewhere?
Many thanks!
Post by rray » 22 Jan 2013, 18:32
Hi & you're welcome!
I realize this would be cool, am afraid though that's not possible because of limitations that the "point cloud lookup" node has which is used inside the compound. Problem with that is that it can only look up attributes like "position" from one particle at a time. Actually it does multiple but this results in a mash up of attributes which makes it impossible to extract the position of multiple particles.
Maybe there's some other way to do that which I've not discovered yet.
kykeon
Post by kykeon » 22 Jan 2013, 21:21
Thank you.
I realize it will not feet my needs for making a snake skin, even with the abilty of using the alpha. Too bad, because it was theoricaly a good way to avoid streching of the scales when part of the body inflate... As you said, I can't find a way to get the direction for overlapping properly one scale after another. As we can see here:
Also I realize there is probably no way to get the color attribute to change colors of the scales to create this kind of pattern
for example.
I will probably do it with a "feather" particle system or may be by textures dependings of the look the director is looking for.
Any ways, I will definitly use it in a way or another for another purpose, the bark Paul Smith did for exemple or may be his gravel simulation.
Many thanks! Cheers.
Post by rray » 30 Apr 2013, 00:20
kykeon I hope you'll find a good use. Cheers!
There's an update (first post of this thread/rray.de) . V1.5 adds Paul's idea, the ability to read the texture offset from an ICE attribute (similar to what is done with the rotation). Previous method didn't work well with animation. Be warned not tested much yet %-(
Pooby
Post by Pooby » 30 Apr 2013, 20:15
https://vimeo.com/65171697
thanks for the update
