K Means Clustering
K-Means ClusteringAuthor: Constantine Tarasenkov
Partitions a polygon mesh with the k-means method.
In the thread linked below, Constantine shows some applications of that method.
local backup: k-means.rar
iamVFX
Re: K Means Clustering
Post by iamVFX » 14 Oct 2012, 07:54
Can you rephrase the question please?
Post by Bullit » 14 Oct 2012, 09:30
Ok. Thinking about it again it is more the case of turning several objects into a unique object conforming to a reference form.
iamVFX
Post by iamVFX » 14 Oct 2012, 11:52
K Means Clustering compound provides unique island indices by which you can filter and move points as if they were a separate object, if you mean it
[rimg=250]http://img59.imageshack.us/img59/9571/30fb5cfd29454a4388e3ac0.png[/rimg]
Post by Bullit » 14 Oct 2012, 14:39
But unique objects are necessary for export for other packages i think.
gustavoeb
Skype: gustavoboehs
Post by gustavoeb » 14 Oct 2012, 18:55
Looks very intersting for stone walls, or stone giant creatures and stuff... :D
good job
Gustavo Eggert Boehs
Ahmidou
Post by Ahmidou » 14 Oct 2012, 21:39
@bullit: Then script it, polygon island are easy to isolate via the SDK! And by the way, you can't create new objects with ICE
Falam
Post by Falam » 14 Oct 2012, 22:24
iamVFX wrote:K Means Clustering compound provides unique island indices by which you can filter and move points as if they were a separate object, if you mean it
Beep, Beep, back up for a minute :) This compound can take a solid object, and break it up as though it was modeled separately, is that what I read correctly ?
iamVFX
Post by iamVFX » 15 Oct 2012, 04:19
Falam wrote:Beep, Beep, back up for a minute :) This compound can take a solid object, and break it up as though it was modeled separately, is that what I read correctly ?
Not exactly... It breaks up geometry on islands, as if you break object with some sort of shatter tool but within of ice. And by breaks up I mean just gives the unique indices to random polygon clusters (see the screenshot from the first post).
If you want to break up the geometry by its existing polygon islands, see Guillaume's Polygon Islands Transformation using ICE, it's pretty effin awesome tool for all sorts of procedural animations.
gustavoeb wrote:Looks very intersting for stone walls, or stone giant creatures and stuff... :D
With such power we can make Flintstones movie!
But really not just for stones... The only limit is your imagination.
[rimg=650]http://img202.imageshack.us/img202/9987/b120de02b3c841afb3d6f43.png[/rimg]
Post by Rork » 15 Oct 2012, 08:16
very cool! :)
keep them coming, this kind of stuff should be shown out of the forums more often.
we're not just a particle app people!! =))
iamVFX
Post by iamVFX » 15 Mar 2013, 18:04
Compound is updated, now you can feed custom array of center points to it
Mr.Core
Skype: giga-core
Post by Mr.Core » 23 Mar 2013, 00:20
Yes, you can! Everyone can, I continue my K.I.S.S. workflow. And the most funniest part - that formula that you showed me - I don't understand it and I'm not used it
I guess that's not KISS, but partial understanding of the k-means article. What you show here is just a search for closest center from array of centers to each particle. And looks like you can improve this bruteforce search by get rid of the last "Find In array Node"
I got 3.3 sec against 5.0 when did this removing on 1k centers.
iamVFX
Post by iamVFX » 23 Mar 2013, 08:34
This is embarrassing :D You're right, there's no need for second Find in Array node
olivier jeannel
Post by olivier jeannel » 15 Apr 2013, 12:49
Hi there,
Trying to reproduce the "Transferring cluster ids to disconnected island polygons" Ice Tree http://img542.imageshack.us/img542/2598/0d727d412162497faefb6bf.png
I get context troubles either connecting the "Cluster To Center Indices" output to the disconnect Islands" input or
to the "3d vector to 4d vector" input.
(Ice tree is on the Dragon polymesh) (but doesn't work either on the pointcloud)
I'm missing something probably obvious here...
A little help ?
iamVFX
Post by iamVFX » 15 Apr 2013, 13:06
Dive into the K Means Clustering compound and replace Get Point ID and Get Point Position nodes to Get Polygon Index and Get Polygon Position respectively
olivier jeannel
Post by olivier jeannel » 15 Apr 2013, 13:30
... I love you man :D
iamVFX
Post by iamVFX » 15 Apr 2013, 14:55
do not
