AI Cut Geometry By Alpha
AI Cut Geometry by AlphaAuthor: MJD Boukhari @ AI Production
This ICE compound cuts polygon meshes by any stencil image/image alpha which is UV-projected on them. Usage video is available here (archive), coproduced by MJD's friend Nour Almasri. This video by Fabricio Chamon shows how to create a cracked surface using FX Tree painting and the AI Apply Thickness plugin (which is also written by MJD Boukhari).
This compound was introduced by MJD's coworker at AI-Production and si-community user eternal art in the thread linked below.
local backup: AI Cut Geometry By Alpha.xsicompound
olivier jeannel
Re: AI Cut Geometry By Alpha
Post by olivier jeannel » 29 Aug 2012, 15:23
Excellent Compound ! Works super, super handy :) Thank's lot !
In the "Delete Polygons" sub-compound, I just exposed the "less than equal" second value. It react as a threshold RVB value to delete more or less polygons.
One question : In the "Crack Modeling" video, there is a "Filter Edge By Angle" compound.
Where can I get it ?
Again, Thanks for the great work !
Boris
Post by Boris » 29 Aug 2012, 17:10
Maaan i have good news for you ! You are Rock ! :-bd Thx you !
Oops ,something went wrong :D
mjd3d
Post by mjd3d » 30 Aug 2012, 18:57
olivier jeannel wrote:Excellent Compound ! Works super, super handy :) Thank's lot !
you can find it here:
viewtopic.php?f=19&t=1933
spurv
Skype: patodigital
Post by spurv » 03 Sep 2013, 10:37
I'm not getting the same nice results with 2014, anyone has the same problem?
Eu é que tou com cenas? Tu é que tás com cenas!
http://lickingtheice.tumblr.com
http://www.mariodomingos.com
xsisoft
Post by xsisoft » 16 Jan 2019, 13:50
" I'm not getting the same nice results with 2014, anyone has the same problem? "
Installed in softimage 2015 WIN7x64 sp1, started testing -1 times worked (as in the attached video- from the alpha channel of the logo xsi, the geometry was obtained! Further the compound ceased to work correctly, makes geometry, but some kind of squares! tested on other versions of 2013, 2014, the result is the same.
The result is a need for version 2012 SAP - as in the demo video
Who does the compound work correctly, and with which version of the softimage & windows OS ?
xsisoft
Post by xsisoft » 17 Jan 2019, 13:24
The problems were in a falling off texture projection, everything works in softimage 2015
