quickPrimitive
QuickPrimitive v0.93Author: Piotrek Marczak
Updated September 2012 to support light primitives, new preference options. Following the popular QuickInset modeling tool (listed below), Piotrek releases this new custom tool, allowing the user to draw primitives interactively.
This can be done using a number of preset objects (pickable from a radial array), and using a variety of placement/creation options such as on surface/on scene grid, along curve, align along X/Y/Z axis, create UV projections, snapping, merge etc.
A video introduction is available here. See the si-community thread linked below for more details.
local backup: quickprimitive_093.xsiaddon
TwinSnakes007
Re: quickPrimitive
Post by TwinSnakes007 » 14 Feb 2012, 16:06
Thanks for doing this! :ymhug:
Re: quickPrimitive
Post by origin » 14 Feb 2012, 19:25
Werner wrote:We're loving this tool. Thanks again!
Just one question about scale. Would it be possible to have the true scale under SRT once created?
No matter what size geometry I create, it always shows scale values of 1,1,1
Not a big problem...just wondering.
well, yes, thats the advantage of using primitives, your scale is always 1,1,1 and only primitive properities change (like 'size' for cube, or radius for sphere)
Re: quickPrimitive
Post by origin » 14 Feb 2012, 19:28
ActionArt wrote:One thing I noticed, even with no snapping activated, it seems to snap to points on other objects. That's great most of the time but perhaps a way to deactivate snapping completely when desired.
by other objects you mean 'not selected'?
Re: quickPrimitive
Post by origin » 14 Feb 2012, 19:47
EricTRocks wrote:Would be nice to be able to change the size of the yellow plane as well.
I can add preference for that. And maybe for shift key (snap to nearest value) too, now it's reading values from scale increments preferences
sant0s
Re: quickPrimitive
Post by sant0s » 14 Feb 2012, 20:13
thx a lot, great plugin! :)
Re: quickPrimitive
Post by wireframex » 14 Feb 2012, 20:19
Thanks a lot
It works perfectly, wonderfull tool you have made :-bd :-bd
Re: quickPrimitive
Post by ActionArt » 14 Feb 2012, 20:46
Yes. For me it snaps to points on unselected objects when snapping is not active.
SreckoM
Skype: srecko.micic
Re: quickPrimitive
Post by SreckoM » 14 Feb 2012, 20:58
Autodesk hire this guy damn it!!!!
- H -
Re: quickPrimitive
Post by origin » 14 Feb 2012, 21:04
I see. Right now tool's scope is the scene (so everything). I was thinking about adding 3 more little buttons (work on: grid | selected objects | scene)
Re: quickPrimitive
Post by ActionArt » 14 Feb 2012, 21:13
That would be perfect.
Leo
Re: quickPrimitive
Post by Leo » 14 Feb 2012, 23:57
We need this in every installation of softimage. This is beyond useful!
bottleofram
Re: quickPrimitive
Post by bottleofram » 15 Feb 2012, 03:14
I have a question: how does it decide on what length to snap when holding ctrl?
I figured if you drag on the grid diagonally it will snap on grid points (pic1). Sometimes it has this .999 value which i assume is indefinite 9's problem, but other than that, it works. What would be brilliant is if you could snap the length on objects points or edges (pic2). With circular objects it seems to work, but not with the cube.
eternal art
Re: quickPrimitive
Post by eternal art » 15 Feb 2012, 09:13
Amazing tool , thank you for sharing .
Toonafish
Re: quickPrimitive
Post by Toonafish » 15 Feb 2012, 09:27
Great tool. Thank you very much !
A thing I noticed is that it works perfectly with a mouse, but with a Wacom holding the RMB to define the height doesn't seem to work very well. Even though I hold the RMB on the wacom pen, I can't seem to drag the height as far a I need, it stops almost immediately after clicking the RMB.
Has anyone else with a wacom noticed this ?
Memag
Re: quickPrimitive
Post by Memag » 15 Feb 2012, 09:38
Toonafish wrote:Great tool. Thank you very much !
Yes ,well you have to RMB (on stylus) while you keep your stylus pressed down (like LMB) , and then drag. If you lift it up , it ends the height operation (as if you released LMB).
Just try not to lift it from the pad until you're done. Works the same way as mouse, but it's not so comfortable combo (press[LMB] + RMB + drag) on wacom.
Re: quickPrimitive
Post by origin » 15 Feb 2012, 10:16
Hi, it's unwanted behaviour, I will change that (you won't have to hold lmb while height adjusting)
