My Wishlist for Softimage... maybe 2013 ?
mattmos
Re: My Wishlist for Softimage... maybe 2013 ?
Silver Subs.
Viewport updates (RT lighting/shadows/AO etc)
Texture Editor update.
Polygonizer version update.
Sculpting tools.
Incoprorating some of Ciaran's ice workflow tools.
ICE Kinematics to be tackled properly - reliable compounds for arms/legs/spine etc.
Default options for delta ref models to be more locked down.
Jitter options in Animation Editor.
Curve tools serious update.
Syflex per point context.
MR speedups.
Silver Subs!
Was there an official announcement I missed while I was away for the last month? At a time when budgets are diving small companies and freelancers will really feel the effects of that crazy decision. Which makes it harder for the bigger companies to recruit experienced staff.
Sculpting tools.
MR speedups.
Silver Subs!
Chris_TC
That's because 3ds is a very destructive modeler. I don't think this will (or should) ever be handled differently, as you keep all construction history alive.b wrote:Like moalso think that merging objects should be much easier. In 3ds max, when you add an object to another one, you do not need to create a new entity, so you preserve the name, the hierarchy, the animation... So, so simple.
Curve tools, curve handing, tweaking and creation written from scratch. See rhino3d for reference...max splines are good too.
actually this request is pretty common. It's about not creating a new object but doing the operation on the current object's operator stack. It's a totally reasonable request and it may be possible for a user to do with ICE modelingChris_TC wrote:That's because 3ds is a very destructive modeler. I don't think this will (or should) ever be handled differently, as you keep all construction history alive.b wrote:Like moalso think that merging objects should be much easier. In 3ds max, when you add an object to another one, you do not need to create a new entity, so you preserve the name, the hierarchy, the animation... So, so simple.
benoit81
Chris_TC
I've attached a compound. But I don't know how to make a cool menu command that let's you pick the "OtherObject". I definitely have to start looking a bit into scripting, because this bit of user convenience is always where I get stuck.benoit81 wrote:How ?
benoit81
Thank you very much. Is it possible with ICE to preserve also texture UVs (and also, if the 2 objects have different materials to create new clusters) ?
kind regards,
kind regards,
Chris_TC
You can definitely preserve the UVs, I can update the compound if nobody else does.benoit81 wrote:Thank you very much. Is it possible with ICE to preserve also texture UVs (and also, if the 2 objects have different materials to create new clusters) ?
kind regards,
You can also assign materials through ICE, but I'm not sure if you can read out which materials are used on the input objects.
One big problem I have with the ICE UV workflow is that the resulting UVs are not displayed in the UV editor. And when you freeze the object (i.e. losing the ICE tree), you also lose the UVs. This is something I'd like to see fixed in 2013, and it can't be that difficult to implement?
When I freeze an object with ICE UV and material assignment, it seems reasonable to expect that Soft will bake down the UVs and make cluster materials.
Oh, and when you add an image clip to the material, it does not automatically use the ICE projection. You actually have to select the one entry from the drop down list for it to be used, which is, um, not ideal.
Maybe that's something for the wish list. Some slick ICE tools for making menus and putting the tools where you want them in the UI without scripting.Chris_TC wrote:benoit81 wrote:But I don't know how to make a cool menu command that let's you pick the "OtherObject".
Chris_TC
That would be awesome. They wouldn't even need to build in that many things. Usually it's about picking one or more items: objects, polygons, edges or points as input for a compound.ActionArt wrote:Maybe that's something for the wish list. Some slick ICE tools for making menus and putting the tools where you want them in the UI without scripting.Chris_TC wrote:benoit81 wrote:But I don't know how to make a cool menu command that let's you pick the "OtherObject".
Well, actually it doesn't seem all that hard to deploy ICE compounds with a built-in picking session. Look at this page of the User's Guide and notice the "Picking string for operator" definition for input ports.
I haven't tried this yet myself, but one would assume that either the "Applying Trees as Compounds" or the "Adding Compounds to Menus" parts of that page should result in enabling you to apply ICE compounds with picking sessions, where necessary...
Or am I missing something here yet again?
Thanks for pointing that out. I thought it used to only allow you to add to 1 user menu. Either it changed or I was just wrong the first time
Luc wrote 'may' be possible.
We are talking about some kind of post-modelling stack. The place where you can drop e.g. symmetrize polygons op and you would have a live update of this modifier when modifying your mesh. Would be cool...
Chris_TC
Oh yes, that's a good one. I've found myself desiring a post modeling stack several times. My latest idea was to model a car rim with say five identical sections. You could have a compound on top of the modeling stack that copies, rotates and merges everything together as you work.origin wrote:We are talking about some kind of post-modelling stack. The place where you can drop e.g. symmetrize polygons op and you would have a live update of this modifier when modifying your mesh. Would be cool...
benoit81
Happy to know that it's a "reasonable request". I suppose that everything that make Softimage much more productive should be reasonable ?luceric wrote:actually this request is pretty common. It's about not creating a new object but doing the operation on the current object's operator stack. It's a totally reasonable request and it may be possible for a user to do with ICE modeling
So do you think that "attach" can be done with ICE properly : I mean preserving the animation, the UVs, the clusters, the hierarchy, (etc.) ?
gustavoeb
- Skype: gustavoboehs
This guy Mattmos nailed it! Really!Silver Subs.
Sculpting tools.
MR speedups.
Silver Subs!
I would only thrown in...
Freeing the topology nodes (or just throw in a post-something on top of the stack as it was discussed)
Ability to read and write kinematics into animation layers (now you can only get and set local or global)
ICEKine should not only be more reliable but have a whole lot easier and unified workflow. So we can move on from the legacy way of rigging.
Gustavo Eggert Boehs
