Just a note, Hirazi's suggestion is a reasonable one and it works but it will still get you a texture path error since those are defined in preset files. There aren't many of them that have a texture but it would still require some work to fix them all.Hirazi Blue wrote:The easiest way to get this to work in a workgroup would be replacing all the "$XSI_USERHOME" strings in the toolbarfile with the ending ".xsitb" in a text editor by the string of the actual path to the workgroup you've installed it in...Ramon wrote:Why not work with my workgroup?
Softimage Shader Presets
Max shader presets Maximus presents his expanding collection of shader presets. The .xsiaddon contains
a toolbar with thumbnail previews (See this image), a custom layout (having that toolbar integrated), and Material presets for the
Material Manager. Note that for some of the shaders to work, the Enhance XSI Shader
collection and/or Daniel Rind's Diffraction shader are required (for both see below).
The current version requires installation in USER directory (drag'n'drop does that)
for the toolbar to work.
For more details and updates see the si-community discussion thread.
local backup: Max_Shaders.xsiaddon
author link: n/a / si-community thread
bottleofram
Re: Softimage Shader Presets
Thanks for your shaders, Max!
caledonian_tartan
i manually added a line to the setenv:
set WG_Path=\\3d01-xp64\SOFTIMAGE\SI2011_WORKGROUP
with that i can simply use links to my workgroup like with the userhome variable...
(XSIUtils.Environment("WG_Path"))
Now i just replaced all XSI_Home inside Max Shaders.xsitb with WG_Path and everything works in a workgroup.
SI 2015 @ WIN7-64
jonatas
This is away to cool.
I'll try them today.
(I'm replying just now because I don't do any 3D in a while)
adinnin
Does this only Work on 2012 ??
is there any chance you may have an old vers for 2010 ?
Alex
Alex
artmanphil
- Skype: artmanphil
They look gorgeous! I like the rough metals the most.
But you should change the links to most of the textures, since only marble_red_diff and _refl are linked correctly. Is there a way I could change it myself?
artmanphil
- Skype: artmanphil
No preset really works - using 2011SP1 - is this a compatibility problem?
Yes they were packed as 2012 sp1, so they wont work with 2011.artmanphil wrote:No preset really works - using 2011SP1 - is this a compatibility problem?
Tenshi
But they work really well on Softimage 2013SP1, so thank you Sir!Maximus wrote:Yes they were packed as 2012 sp1, so they wont work with 2011.artmanphil wrote:No preset really works - using 2011SP1 - is this a compatibility problem?
Maybe a little update? hehe.
well....
create a whole bunch of awesome materials, send them to MAX and maybe he'll implements them in the next update... ;)
