Create Polygon Meshes from Instance Shapes
Create Polymesh from Instance Shapes
This ICE modeling compound merges all of a pointcloud's instances into a single polygon
mesh, which may be frozen afterwards. UVs and Materials are preserved during the operation.
For a video SWF and some more information on the compound see the si-community thread.
Note that this addon is included in Guillaume's »ICE modeling tools«
collection.
local backup: CreatePolyMeshFromInstanceShape.zip
collection.
author site: http://frenchdog.wordpress.com / si-community thread
izze
Re: Create Polygon Meshes from Instance Shapes
Great compound. Is there any way to export the mesh with UV's?
Thanks,
Thanks,
pylo
i cant get it running poperly.
when comparing the simulation cloud and the polygon cloud you can see that they are noch on the same possition.
grahamef
It looks like you've either moved the point cloud or the mesh. Just make sure that everything is at the origin.pylo wrote:i cant get it running poperly.
pylo
Ok that was the fault... thanks
My compound is still red but it seems to work so far...
Can you also help me with the shading... I cant bring the source shader on the calculated polymesh.
perhapes another tutorial that shows a bit more what you do, to get it working.
grahamef
You need to use the ICE attributes Materials and MaterialID to set the materials on the instance masters. Watch the swf file and look at the sample scene to see how it's set up. There's also more info about Materials and MaterialID here: http://download.autodesk.com/global/doc ... d30e297728pylo wrote:Can you also help me with the shading... I cant bring the source shader on the calculated polymesh.
j3st3r
Hi
I have an issue with this stuff. I tried to use it with Instance on Curve addon, and when I adjust parameters of the delete group, it is reflected well on the generated polymesh. That's the same with random scale parameter in the compound, the generated polymesh became quite different than the pointcloud. Any idea?
will_grello
@J3st3r I aam having the same issue
bvmadjen
sorry to re-raise a dead topic, but I can't download this file because of a 500 internal server error.
Kolya
hello, it's strange that it gives a link to a .zip file when it's actually .rar here is the correct link : http://si-community.com/download/lb/gla ... eShape.rar
M3D
hi guys, hi guillaume,
I hope you can read and answer me,
I'm a softimage user, I will never abandon it!!!!,
I'm very interested in your compound, I created a particle animation with realflow, imported it into softimage, inserted meshes instead of particles (grains of sand) and I want to export the animation to octane render,
octane doesn't read the particles I entered, the only way is to use your compound.
Can you give me instructions on how to use it?
Thank you!!!
Thank you!!!
scon
Can't you just export the meshed cloud as alembic, for octane to render?
M3D
no, octane imports almbic particles but matches them with a standard geometry, a sphere, not the instances
scon
Don't export the point cloud, export the meshed cloud. As alembic and geometry only. Have a look at the example scene from guillaume. Plug the pcloud and the instance shape node into it and thats pretty much it. Don't know if you will have much fun meshing and exporting millions of points though.
M3D
Thanks for the advice, but I don't really understand how to do it
M3D
I have a scene where I see leaves, is that the scene?
scon
I don't know what you have. The rar file includes one scene. If you have downloaded that file, that's probably the scene.
