I updated the archive with plugin (staring as "Array" command in Edit menu) and a bit revisited compound.
If using command from EDIT menu, you'll be prompted for a picking session.
First you pick object you want to copy,
second, you can choose another object if you want to distribute copies on it's points.
I still didn't get to toss edges and polygons as option.
You don't have to pick either , so you can manually pluck ICE tree.
ICE tree will be nested in an empty mesh called Array.
There is also a small visual helper (colored vector with name) for MAIN, A and B parameters.
Cheers!
Hvala SreckoM.Nadam se da ti koristi.
Pozdrav!
Array tool
bottleofram
Re: Array tool
Very useful indeed. I wasnt able to make plugin work but compound is immense. Now, on to making instant walls and braking them with momentum.
On a more serious note, is there a way to make tabs on compound ppg? With something like this it would be good to have a bit of separation for each axes...
Thank you
A sada iznenadjujuce poznat jezik. Hvala
Thank you
Memag
Re: Array tool
What's wrong with the plugin, can't load it or the command doesn't work?
I thought of organizing it but I don't know how to customize a PPG for ICE operators.
Sorry.
Sorry.
Re: Array tool
The options to customize an ICE compound PPG are very limited, as is described here
Memag
Re: Array tool
Thanks HB! Will give it a try.
edit: updated PPG (no tabs still)
Re: Array tool
Where do I find the latest version?
Memag
Re: Array tool
At the bottom of the first post.
bottleofram
Re: Array tool
Sorry, the plugin works just fine. I renamed the compound for easier identification which, naturally, messed it up. My bad.
