User .obj library
User OBJ LibraryAuthor: Reinhard Claus
A menu builder for a library of .obj files. As the first step, you'll have to create a folder named »ObjLib« under (UserFolder)/Data. When installed, creates a menu in Get>Primitive. Folder structure in the ObjLib will be recreated as the menu structure in Get->Primitive->User Object Library. Works for wavefront obj file format only — (Update) new version also scans all existing workgroups for Data/ObjLib submenus.
This addon is now integrated in the STL/OBJ Import/Export addon: AdditionalFileFormats.xsiaddon
Re: User .obj library
Post by rray » 18 Sep 2023, 17:44
:x
Nice to see you and also to see some more activity around here lately! some catching up to do. Time flies! :-ss
Talik
Skype: nihao00042
Post by Talik » 23 Jul 2024, 11:57
I don't know why but after using this plugin with big meshes it crushes and breaks obj file. I don't know why. Probably because of big file size or multiple meshes per file
Post by rray » 02 Aug 2024, 20:19
I just used the built in importer, maybe the file was locked after it failed to import.
I uploaded a new version that uses my own importer. Maybe it works better, it should at least be faster (also it selects the newly imported object)
Talik
Skype: nihao00042
Post by Talik » 03 Aug 2024, 00:01
Built in importer failed to import those obj files too. I just deleted materials and made meshes one object and it worked.
Updated script doesn't import obj files from old obj library folder
Post by rray » 03 Aug 2024, 05:37
for the updated version, does it output something in the script log?
Talik
Skype: nihao00042
Post by Talik » 03 Aug 2024, 22:03
Yes it said cannot find a java script when trying to import .obj files from old folder
Post by rray » 01 Nov 2024, 21:05
I merged my custom STL/OBJ importers and the ObjLib plugin. User needs to set the base directory (that's going to be menu-fied) in the "File Format Options" section in preferences. It also scans the old Data/ObjLib folders for backwards compatibilty. Hope it works this time :-ss
