OSM to Si
OSM to Si updated March 2025 — A set of ICE tree nodes to open OSM (Open Street Map) files and convert them to geometry.
Imports features such as buildings, streets and trees and has a number of conversion
options, for example for building height etc.
See the si-community thread for example renders. From the zip's readme: installation : put in a similar directory: c:/Users/Alex/Autodesk/Softimage_2015_R2-SP2/Application/Plugins/nt-x86-64/osm_to_si_19
If you need compounds, place the OSM_to_Si folder in a similar directory: c:/Users/Alex/Autodesk/Softimage_2015_R2-SP2/Data/Compounds
The weld vertex function is quite slow, so you should not use it on large objects.
You can download the OSM map here: https://www.openstreetmap.org/#map=14/55.40032/43.83536 (limited number of nodes) / http://extract.bbbike.org/ (unlimited number of nodes)
Description of osm tags: https://wiki.openstreetmap.org/wiki/Map_features
height map: https://tangrams.github.io/heightmapper/#12.08/55.3418/44.0386
local backup: osm_to_si_v.1.02_3.04.2025.zip
SitoH
Re: OSM to Si
This is super cool! Thank you for sharing , mr_alca
