try remove all of those files, and restart SI to see if them still cached?Talik wrote: 14 Sep 2023, 19:49 How to remove a command from the Keyboard mapping menu?
Here I did custom scripts. I modified a script and rewrote it and now I'm having two commands. One of them doesn't work. These commads exist in Keymap Mapping menu even if the script is been removed.
On the bottom the Data/Scripts folder
Hotkeys
Re: Hotkeys
Talik
- Skype: nihao00042
Re: Hotkeys
Same. The scrpt exists in Keyboard mapping but not in the shelf you showed. Changing details in the toolbar you showed doesn't affect the Keyboard Mapping
The names in Keyboard mapping still exist even after deleting the scripts. But don't work. Unable to delete these scrokes or change the names of existing scriptsopoppopopp wrote: 18 Sep 2023, 18:49try remove all of those files, and restart SI to see if them still cached?Talik wrote: 14 Sep 2023, 19:49 How to remove a command from the Keyboard mapping menu?
Re: Hotkeys
what is the path of your bottom picture? (black)
Talik
- Skype: nihao00042
Re: Hotkeys
It's Data/Scripts folder
Re: Hotkeys
OK, and I know your problem.
You drag scripts to Toolbar to create those files & custom commands.
The intended way to remove the command you created is Right Click that button, and click remove command.
and I won't retyping the manual any further. just search "remove custom commands" in the manual.
The solution should be something like:
After you clean everything, just restart to take effect of your hotkey manager.Right-click on an empty portion of any custom toolbar and choose Customize.
Under Command Categories, select Custom.
Under Available Commands, select the command you want to remove.
