not me, I know essentially nothing about Mudbox and have no opinion of it. ;)xsi_fanatic wrote:Don't say that ! luceric might get offended.ace63 wrote:Mudbox looks fine at first glance, but once you actually try to work with it you quickly will struggle to achieve anything at all. It lacks totally basic tools and functionality and is buggy as hell. We actually tried using it on several projects but literally everyone gave up on it.
Mudbox at 10$/month
Re: Mudbox at 10$/month
I can tell you some of my experience with it when i tried:Bellsey wrote:Would someone care to elaborate on what it was they were trying to in Mudbox. It would be interesting to know what led people to be so negative about it.
Mudbox has excellent true 3D sculpting and painting abilities, both of which are vastly underrated by many people. And it's actually used very extensively in more places then people might realise. Zbrush and MARI are very fine packages, but in some areas (imo) Mudbox beats them hands down.
Another thing to also note, is that together with the new desktop subscription plan for Mudbox, the perpetural license price has also changed as well, with a standalone seat now costing just a little over £500.
3d sculpting:
it is very slow and clunky compared to zbrush. I suppose Mudbox requirements are way too high in terms of GFX card, same machine same gfx card (nvidia geforce 550) performed crazy good with Zbrush and performed very poorly on Mudbox (this shouldnt happen considering Zbrush is 32 bit, mudbox is 64 bit, so targeting high end card just to have nvidia sell more is very bad call, and this is one of the reason most people dont touch mudbox for sculpting).
The viewport gets slow very fast as soon as you start subdividing, the cursor lose precision when sculpting due to laggy/clunky movement. The fluid feeling you have in Zbrush while sculpting is totally unexistant in Mudbox, i assume as i said is because of the GFX requirement (which again shouldnt be).
Very different pentablet sensibility, Zbrush has a very high pentablet sensibility while sculpting, Mudbox makes you go nuts, sometimes i have to turn up the strenght so high to obtain a result that is just wrong, Falloff are also very weird to control.
Lack of sculpt brushes, Zbrush here reigns hands down, Mudbox has very very basic sculpting brushes, and you have to play a lot with falloff (which is tedious, poorly documented, annoying) to get a decent result.
Painting:
I have no critics about its painting system, i consider it way better than everything on the market atm unless you need Mari for very high texture resolution.
No wait, I do know one thing about Mudbox, and that's a wild thing to write. ;) ZBrush is not a real 3D OpenGL app, it does not use the GPU at all. It uses voxels (well... pixols, which is where the company gets its name) and a software rendering for the viewport. That's why it's fast, but it's suffered from clunky workflows because of it. Mudbox is a real 3D app; the whole point of creating mudbox originally at Weta was to have a real 3D engine. And yes, that doesn't scale as well as a voxel-based app for huge details, but that's the approach, it isn't collusion with nvidia ;)Maximus wrote: I can tell you some of my experience with it when i tried:
3d sculpting:
angus_davidson
- Skype: ithacapellin
I like the look and feel of Mudbox and its workfolws and layout are definitely better then Zbrush. Zbrush is definitely more responsive at higher detail levels.
That been said I found 3d Coat to be the best mix of workflow and speed and is the one I prefer using.
Technomancer at Digital Arts
Wits University
Wits University
angus_davidson
On the subject, why cant Softimage be released at $10 per month ;)
Wits University
Wits University
ronaldomiranda
YES, yes.angus_davidson wrote:On the subject, why cant Softimage be released at $10 per month ;)
myara
Because no matter how you think about it, that move would make them lose money ?angus_davidson wrote:On the subject, why cant Softimage be released at $10 per month ;)
I haven't used Mudbox that much, and I've been using ZBrush and testing 3DCoat, but with this new price I'm considering Mudbox too, at least for painting.
Mari is a little pricey and too overkill for my needs.
M.Yara
Bellsey
This is correct. Conversations I've had with Andrew (one of Mudbox's co-creators), he's explained that one of the goals of Mudbox was to always to work with the asset 'on target'. So you're always working on the actual asset in true 3D, not some kind of representation, or avoid having to flick between some kind of preview mode to see a final version.luceric wrote:No wait, I do know one thing about Mudbox, and that's a wild thing to write. ;) ZBrush is not a real 3D OpenGL app, it does not use the GPU at all. It uses voxels (well... pixols, which is where the company gets its name) and a software rendering for the viewport. That's why it's fast, but it's suffered from clunky workflows because of it. Mudbox is a real 3D app; the whole point of creating mudbox originally at Weta was to have a real 3D engine. And yes, that doesn't scale as well as a voxel-based app for huge details, but that's the approach, it isn't collusion with nvidia ;)Maximus wrote: I can tell you some of my experience with it when i tried:
3d sculpting:
The trade off with that is performance once things get more complex and you need a decent 3D card, but you can say the same for many most 3D applications. Mudbox does have some preferences where you can tweak some settings to get more performance, which in some situations can really improve things.
angus_davidson
Lukily Mari is part of the production collective that we get mainly for Nuke. Although Heiro is pretty damn amazing once you get into it as well. You do however need a beefy pc to do stuff nicely in Mari as well.myara wrote:Because no matter how you think about it, that move would make them lose money ?angus_davidson wrote:On the subject, why cant Softimage be released at $10 per month ;)
Wits University
Wits University
Don't want to be positive, but, for me, this is looking more like a part of their new expansion into small 3d business. Together with that 123, 360, LT or whatever thing. Don't know for Mudbox, but Maya LT and Fusion 360 ( that's what I tried), they are very impressive for price. Only playback of Maya LT makes the all Modo animation tools to be a bad joke.Total bad joke. Same for modeling. Plus additions like substance. It also has complete (if I'm correct) NURBS tool set of big Maya, and it's able to export that as NURBS, through FBX.
I mean, people here have all reasons to hate AD, but this should not be reason to cut self, from using some really good tools.
Dwindleflip
Zbrush destroys mudbox in every way it really matters except texture painting and it does it with an aging 32bit platform with some 64bit external functions like decimation master. Mudbox lacks so many modelling tools at this point that it cant even be compared to Zbrush as a modeler.Bellsey wrote:Would someone care to elaborate on what it was they were trying to in Mudbox. It would be interesting to know what led people to be so negative about it.
Thats not to say I dont enjoy sculpting in mudbox. Sculpting in true 3d view ports with actual subdiv base meshes, layers with layer masking and better texture tools than zbrush is great. Mudbox has amazing potential, but it never gets there. There are no noise tools in mudbox, no move elastic, no move topological. no dynamesh, no Zremesher, no hair, no fur, no curve deformations, the brush system is underdeveloped, there is no real cavity masking, no edge looping, edge paneling, poor scene management, mesh extractions, geometry creation is non existent, no tri planar mapping, no tiling for texture layers, no filters for textures, no adjustment layers for textures, no udim, no color management, no BRDF shaders that mimic all the common shaders we use today, the bones system is broken, no transpose like tools, no zsphere, The list is getting huge and I only mentioned a tiny portion of it.
EVEN WITH THAT said... Mudbox itself still has incredible potential and it is useful.
Bellsey
As I've said, Zbrush (and MARI) are fine packages with many fine qualities. They do their thing and Mudbox does its thing.
I'm not going to get into a feature war between Mudbox and Zbrush. Like for like comparisons often end up providing an unreflective and unbalanced views. Mudbox may not have some of the exact and precise features listed, but it might have similar ones that deliver the same result. You don't have to go very far to fine some excellent work produced with Mudbox that easily matches and that of other packages, so that proves that Mudbox is actually, more than capable. So, then it often comes down to how the package is used (individually and in a pipeline) and who uses it.
