Finally, after some hard work, and some hits and misses on the way, I finally got the bezier patch working. It is not a "surface" by Softimage definition but a polymesh, the end result is very similar.
Below is the bezier patch result and the ICE tree. It is controlled by 16 nulls and just for fun I cranked up the subdivision to 30 in U and V.
The bezier definition does work, although with very high subdivisions, I get weird results, probably because of the precision of some of the calculation.
Attached is the compound as well. Enjoy!
Curves and Surfaces with ICE - WIP
Re: Curves in ICE - WIP
The next screen shows the patch with nulls moved to create the curved surface. I then selected some points on the patch and pull/push them at will without affecting the rest of the patch.
I also simplified the ICE tree.
The end result is quite flexible. Each bezier node can be modified easily with an other surface representation just by changing the matrices inside each nodes to say, a cubic hermite or catmull-rom.
Like curves, the patch can be connected to one another in piecewise fashion to get larger surfaces. The possibilities are endless.
Cheers!
Dan
Cheers!
Dan
And a quick render of the surface.
Re: Curves and Surfaces with ICE - WIP
Little update.
I was able to correct the quad description error and was able to pass subdivision 50 on the bezier patch. Now I crash Softimage because I run out of memory (I am still working on a very low spec machine by today standards).
Here is a screen grab of the bezier patch at 500 x 500 subdivisions. Useful for some terrain modeling. The picture shows the wireframe so tightly pack it's showing white! I have to zoom in to see the texture!
In the thread Modulo and variant, i provided the screen grab of the quad description compound for those interested!
Now moving to rational bezier surface!
