Sycles 2.4.1 V 2.4.1 released August 2026 —
download page: https://ssoftadd.github.io/syclesSecondGenPage.html / wiki with tutorials / all of Shekn's plugins / author on vimeo / si-community thread
- Skype: ondraise
Hey that's neat.
benoit81
Do you plan to make Cycles for Softimage compatible with rendermap ?
Bay the way, thank you very much for this addition to Softimage : Cycles is very powerfull, and it's a step forward to move to blender
The answer to the question - no. It's because I don't know how to do this. This is the main reason.
Update 1.7. Download here: https://ssoftadd.github.io/download/Sycles_1.7.xsiaddon
What's new:
1. Compiled with the latest version of the Cycles (from 17 September 2018). The most essential updates of Cycles are new shader-node PrincipledHairBSDF and enhancement of Math and Voronoi nodes.
2. Now panorama render works correctly.
3. Rendering motion blur and (in particular) Motion Pass. How to do this - tutorial 26 in the manual from the page https://ssoftadd.github.io/syclesPage.html
4. Support of rendering volume-objects like smoke, fire and other clouds. This is done by storing data in special set of ICE-attributes with the help of one ICE-node. This method allows to render any volume data, in particular OpenVDB, emFluid and Explosia FX. How to do this - tutorials 27, 28 and 29 in the manual.
5. Add parameters of the Mist Pass to the render properties. This pass in some sense is opposite to the Depth Pass.
6. Fix some non-critical bags and errors.
What's new:
Is there an edge rounded shader for Softimage ?
Hey Shekn thanks for the updated version.
sirdavid32
fantastic news! I gotta try the hair shader
Web: http://www.3dcinetv.com
wireframex, edge round shader in Sycles is called Bevel. AO shader is really incorrect, but this is a bug of Cycles, not mine. So, we should wait while developers of Blender fix it. But AO_PASS works correctly. You can use it for rendering ambient occlusion. There is only one option for this pass - AO Distance in Background tab of the render properties page.
Thanks a lot SheknShekn wrote: 24 Sep 2018, 14:07 wireframex, edge round shader in Sycles is called Bevel. AO shader is really incorrect, but this is a bug of Cycles, not mine. So, we should wait while developers of Blender fix it. But AO_PASS works correctly. You can use it for rendering ambient occlusion. There is only one option for this pass - AO Distance in Background tab of the render properties page.
Do you have a simple scene about emfluid rendering or Explosia Fx ?
Phil
How to render emFluids described in the manual, tutorial 28 (link to the pdf: https://ssoftadd.github.io/manuals/sycl ... 18_eng.pdf)
I attach some example file with the scene and two screens with ICE-tree and Render-tree for the volume object. The process of rendering divided into several steps:
1. Simulate volumes as usual. It is possible to use build-in render engine for emFluid for tests.
2. Save data of volume densities to the separate attribute. In fact you should save 4 attributes for each data set: voxels dimensions, voxel cube size (min and max corners) and data array. Data array may consists from float, colour or vector3 values. For convenience purpose there are special ICE-nodes for saving this data (Set Volume Float, Set Volume Colour and so on).
3. Set shader for volume. In shader you should use attribute with saved values by using Attribute node. Without selecting concrete attribute the volume will not be rendered, because the renderer does not know what values used for density, colours and so on.
Thanks a lotShekn wrote: 25 Sep 2018, 07:30 How to render emFluids described in the manual, tutorial 28 (link to the pdf: https://ssoftadd.github.io/manuals/sycl ... 18_eng.pdf)
It seems I will stick SI with Cycles
With SI EOL Redshift / Vray and Arnold have stopped developpment and internal features like fluid / smoke render are missing ... Cycles begin to be very interesting and many shaders are provided
Phil
Nothing interesting here but render is quiet clean
- Skype: ondraise
Very nice! The caustics are quite well done. What settings did you use? Did it use the denoiser?
I use 2 panels (Light objects) + 1 Environment texture + denoising (AA Sample : 800) --> Rendering time 35sDraise wrote: 27 Sep 2018, 16:11 Very nice! The caustics are quite well done. What settings did you use? Did it use the denoiser?
CPU+GPU rendering --> CPU (Ryzen Threadripper 1950X 16-Core ) + GPU (2 GTXTitan + 1 GTX 1070)
AO Pass render test
