3delight tests
Blob StrokesAuthor: Anto Matkovic
Here's a small ICE compound used to generate these 'blob-strokes'. I had something like this before, but I really wasn't so excited by the speed of generation. Now with 3delight, it's definitely feasible, updates are performed immediately. The compound creates particles on curve list, evenly distributed, count is relative to particular sub-curve length (still, you'll need to take care of curve re-parametrization). It's also able to perform 'write on' on one-after-another subcurve (by sub-curve, or normalized by sub-curve length). In short, you can 'draw' 3d strokes with it, by animating the slider value. There are a few additional parameters. [..] contd. under si-community link
local backup: Emit Blobs From CurveList.xsicompound
3DelightAuthor: dna research
v4.0.41 updated Feb 21st 2015. 3Delight is a fast, high quality, RenderMan®-compliant renderer designed to produce photo-realistic images in demanding production environments. The renderer was introduced to the public in the year 2000 after being used for more than a year as the sole renderer in a sister production company. It is now widely used and earning a reputation as a benchmark in rendering technology. [..] (cont'd on product page)
DNA research recently released the 4.0.41 upgrade and extended the free license to support up to 8-core CPUs. Highlights from the changelog (archive): Volumetric Smoke and Shards Any shader as light source projection Exposure, Gamma Controls Mesh Light support ESC to stop render. Last year's big 4.0 update introduced features such as: support for deep EXR files Native MARI textures support Improved sampling of environment maps Added the physically plausible 3Delight Material "Continuous rendering" is now enabled by default Up to x2 acceleration in hair/fur rendering Memory usage is down 30% when using the path tracer Skin shader for 3Delight for Softimage Motion Map property is now supported
A list of movie projects rendered with the 3Delight renderer. As mentioned the product is free of charge for the first 8-core license. Additional quad-core licenses are available for 400$ each and unlimited multi-core licenses for 900$ each. Yearly support and updates 190$/290$ resp.
Comments on work in progress
maze
Skype: manuperou
Re: 3delight tests
Post by maze » 18 Sep 2012, 16:41
Hi Mathaeus,
The scene is looking good! I specially like the fine detail of the fabrics bump (or disp?) on the seat, it does read well although its pretty small..
metal is also looking nice, although you may want to add some glossiness variation to some spots to make a bit less *clean*
only thing bugging me a bit is the boots modeling, shape is not bold enough I think, might be the top ending looking without some sort of cap all around,
also a light shell to the interior might help to gain some weight.
cheers.
Re: 3delight tests
Post by Mathaeus » 18 Sep 2012, 22:10
maze wrote:Hi Mathaeus,
cheers.
Yes this is displacement on fabric, variable reflection's glossy spread as well. Once I'll put everything I want into this scene, if I ever, probably I'll see what to tweak.
BTW if you're coming from Max, maybe a good start with Renderman compliant renderer, is to consider it as an highly boosted Max default scanline renderer - means, shadow map rules... of course plus a bunch of additional features.
Regarding light falloff question from your another post, in 3delight it's the standard SI solution, by enabling falloff in light's PPG, you getting a default exponent of 2, usually considered as 'realistic' one.
Re: 3delight tests
Post by Mathaeus » 25 Dec 2012, 20:09
a few tests of lightweight particles. When particle shape is set to "point", particles are rendered as circles using a specialized algorithm which is suitable for such small primitives. This allows to use much higher count of particles, but drawback is default billboard orientation. Circles are always aligned to rendered camera.
Here's small trick for more interesting shading - desired shading normal is converted to color. In render tree, color is converted to vectors for bump map. Particles are still aligned to rendering camera, but shading normal is modified. ICE tree and Render Tree are something like this. For some reason it seems 3Delight wants a negative of shading normal, here.
And how it looks like. I've used ICE setup which tries to do even distribution on mesh, following polygons. Still it needs work.
Re: 3delight tests
Post by rray » 26 Dec 2012, 01:40
Looking good, how much faster is it compared to your Knit Strands Pro plugin with these woven patterns?
TwinSnakes007
Re: 3delight tests
Post by TwinSnakes007 » 26 Dec 2012, 03:27
That SSS shader looks sooo nice. What's the rendertimes and resolution?
Re: 3delight tests
Post by Mathaeus » 26 Dec 2012, 18:05
yeah I forgot rendering times. First woven is longest - without subsurface on skin, it's about 1 minute, with subsurface, it's about two. Using 4 core 3Delight on QuadCore machine, 1280*720 resolution, 8 light with deep shadow maps, shading rate 0.5. In image, there's really sharp shading rate of 0.1, so this is about twice longer.
Anyway, I wanted effect of first one, ability to add dust or small specular dots, then to add this in post over existing image, somehow. Especially these specular dots are hard to do with displacement, as displacement needs to be "continuous". Another advantage is resistance to shading rate, each particle have own "contour". Woven is some kind of occasional product, maybe it could be faster than mesh, with detailed pattern. But once the particle is moved out of emitter's surface, or it's rendered alone, there's a good number of issues - it does work with ray-tracing, but circles seems to be still aligned to camera, supplying an unwanted target for the ray. It works with point-based GI too, but it's not so fast, nicely to say.
Would be interesting to try this for clouds, or short high-dense fluffy fur, like on teddy bears.
Subsurface is more along line of misss_fast stuff, preset is default, almost monochrome "marble". Subsurface gradient belongs to two Car Paint shaders, adapted to work with 3delight subsurface in similar way to 3dl misss_fast shader (two times stronger subsurface from back side, scattering from back side too, or "Nn" instead of "Nf"). Car Paint is there because of diffuse falloff, to get difference between layers. Base layer is original skin color, using diffuse falloff of 1. Top layer is inverse hue of skin, some kind of blue-purple, using diffuse falloff of 2-6. Idea is to get a "whitening" on high light-surface angle, in additive mix.
Finally, mix is what I call screen with pedestal, which allows output higher than 1, gradually looking like plain additive.
In short, subsurface shader is more for blurring, it could be replaced with some simpler shading model. Skin color is almost uniform.
Here is with - without subsurface comparison.
Re: 3delight tests
Post by Mathaeus » 16 Mar 2013, 22:09
time to redo some old tests, now using a path-tracing engine from 3dl 3.1.35.. From my understanding, this path-tracing engine has to be a part of upcoming 3delight 4 for SI. Everything is ray-traced in these pics. I've used something like ray-tracing as primary ray, ray-tracing as global illumination, around 512-1024 samples for GI, 256-512 for glossy reflections. Image with girl, has one area light. Rest is lighted solely by environment, using equivalent of MIA physical sky (only sky, not classic light together).
On QuadCore machine and 4-core 3delight, render times are: for image with girl, about 20 minutes, metallic structure took about 40 minutes, building took about 2.5 hours - don't know does render-time CSG adds some time, probably it does. It seems that all features of 3dfSI, are working nicely with path-tracer. Hair, subsurface scattering, render time CSG, blobs, all kind of motion blur, displacement... Fine displacement seems to be a nice way to cover the noise, in case of stills.
There is also an especial, general purpose 3Delight material in this version. Didn't used it for now, had no time to redo the materials, so here it's still 3delight's equivalent of MIA.From first look at SL files, there is a lot of new code, at least some kind of new shading op, having a BSDF option. For now, I think fastest option for path-tracing is: ray-tracing as primary ray, without progressive rendering for final. Adding some area lights, removing some GI bounce, I believe this improves the render time. too.
Kzin
Re: 3delight tests
Post by Kzin » 17 Mar 2013, 20:03
nice tests.
rendertimes are a bit high, but i think it should render faster with bsdf once its integrated. it should also eleminate the noise, which is a bit strong for the girl and the building. looking forward for updates.
Falam
Re: 3delight tests
Post by Falam » 17 Mar 2013, 20:57
Mathaeus wrote:Hi,
How are you fairing with 3Delight, are you testing ? I was considering buying a License, Mental Ray nodes are limited in 3Delight and to create your own RenderMan shader you'd need Pixar Node based RenderMan software, another $2K :(
Re: 3delight tests
Post by Mathaeus » 17 Mar 2013, 22:18
Falam wrote: How are you fairing with 3Delight, are you testing ? I was considering buying a License, Mental Ray nodes are limited in 3Delight and to create your own RenderMan shader you'd need Pixar Node based RenderMan software, another $2K :(
Hello Falam,
these three were done with out-of-the-box shaders. There are only few parameters to tweak when it comes to path-tracing, everywhere . Regarding shaders, wouldn't hurt to have some hair shader with shifted highlights, and that's all, imho (which is not hard to put into existing hair shader, btw). New 3delight material should be able to cover all opaque stuff - including subsurface scattering, reflection coating, so on.
I'm not a tester, I believe I'm able to recognize the software, able to return the energy I put into it. Beside 3Delight, this could be Modo renderer and V-Ray, Softimage standard kinematics, Softimage ICE, so on. Of course I'd always prefer a full featured renderer, let's say, deformation blur is a thicket.
Falam
Re: 3delight tests
Post by Falam » 17 Mar 2013, 22:26
Hello Falam,
Would you buy a 3Delight License ?
Re: 3delight tests
Post by Mathaeus » 17 Mar 2013, 22:39
Falam wrote: Would you buy a 3Delight License ?
I already bought what's fit to my machine. Will see if I'll extend it this summer, for purpose of 3Delight exporter for Blender - maybe it's too early to talk about...
Falam
Re: 3delight tests
Post by Falam » 17 Mar 2013, 23:38
What do you mean what 'fit to my machine' ? You're limited to phong shaders for Illumination, maybe I'm not seeing that it's good for NPR renders, therefore phong is all you need ? Do you use any renderman shaders ?
Re: 3delight tests
Post by Mathaeus » 17 Mar 2013, 23:51
Oh come on, I think I didn't used any phong shader since 2004 or so - at least, not plain one.
It's very late evening where I'm, time to sleep....
Falam
Re: 3delight tests
Post by Falam » 17 Mar 2013, 23:59
Mathaeus wrote:Oh come on, I think I didn't used any phong shader since 2004 or so - at least, not plain one.
The Arch Shader I was told doesn't work in 3Delight. Only (1) SSS shaders works in 3D delight, that is not much concern with the SSS within 3Delight. What shader(s) are you using if you don't use phong ?
Kzin
Re: 3delight tests
Post by Kzin » 18 Mar 2013, 00:55
you have two versions of the arch shader in xsi. the mia one and the native integrated, one of these two is working, not sure which at the moment, but i think you can find the informations in the 3delight docs.
