RCTools updates
RcTools 5.3Author: Reinhard Claus
Updated April 2013 — 5.3's main new feature TopoClipboard lets you copy map data from a point/edge/polygon/sample selection and paste it somewhere else on the same or a different mesh into a selection that has the same »shape« as the first selection. Also works for complete selections, which makes sense when pasting across two meshes that have the same topology, but differing point orders. TopoClipboard transfers: Vertex Colors UVs Envelope weights (with a remapping option) weight maps tangents point positions (local »shape« of the selected area). Works across different maps of the same type and across scenes inside one instance of Softimage. Other new features are a topology based mirror/flip selection and a couple of new settings for the custom filters like point position compare components, edge on UV border, edge orientation.
The RCTools plug-in is a collection of workflow helpers and filters for Softimage. The supplied popup menu (Script command »rcToolsPopup«) gives you quick access to all the tools. [..] List of features: Peek (Align camera along selected edge/facing selection @90°;) TopoClipboard Flip Selection Mirror Selection Fill Selection Walk Patterned Loop selections Apply Pattern Customizable Filters (by polygon area, aspect ratio, orientation, edge length, point distance and 30 others) subcomponent clipboard subcomponent clipboard booleans (e.g. Select intersection of current and clipboard selection) Cap holes Repeat
local backup: rcTools.5.3.xsiaddon
Jho
Re: RCTools updates
Post by Jho » 26 Jun 2013, 12:08
Oh right. I just thought it would be a hassle to cut a piece of the geometry out and merge it back in. But it was pretty easy once I tried it. Thanks a lot.
Although it would be nice to automate this process somehow. So that I could just paint away and all the weights would be copied to the other side. Anyways, I'm getting off topic. Thanks again.
Re: RCTools updates
Post by rray » 26 Jun 2013, 12:29
Yes when the other geo is close by, and it's in point context, GATOR works great.
If you were to copy/paste from sample context like UVs, GATOR had some issues, at least last time I tried, so I think I'd try topo-clipboard for something like that first.
julca
Re: RCTools updates
Post by julca » 28 Jun 2013, 10:52
Hello !
I have noticed that the "Cap marked hole" command add a point on an open edge selection like this :
I write a script for this and which can work with multiple objects at once (which use "rcCapHoles" command of course).
set mySelection = createObject ("XSI.Collection")
mySelection.AddItems Application.Selection
set myCollNewPolygon = createObject ("XSI.Collection")
for each currentSel in mySelection
	if currentSel.Type = "edgeSubComponent" then
		for each currentNestedObj in currentSel.NestedObjects
			if currentNestedObj.Type = "primitive" then
				set currentObj = currentNestedObj.Parent
				set myGeo = currentObj.ActivePrimitive.Geometry
				nbPointBefore = myGeo.Points.Count
				'logMessage "nbPointBefore = " & nbPointBefore
				SelectGeometryComponents currentSel
				rcCapHoles
				nbPointAfter = myGeo.Points.Count
				'logMessage "nbPointAfter = " & nbPointAfter
				myPointSelection = ""
				for i = nbPointBefore to nbPointAfter - 1
					myPointSelection = myPointSelection & ", " & i
				next
				if nbPointBefore <> nbPointAfter then
					ApplyTopoOp "Collapse", currentObj.FullName & ".pnt[" & myPointSelection & "]", siUnspecified, siPersistentOperation
				end if
				myCollNewPolygon.AddItems Application.Selection
			end if
		next
	end if
next
SelectGeometryComponents myCollNewPolygon
I don't know if you can/want integrate this on your plug-in but it would be nice.
In any case I hope not to hurt you with my suggestions.
Cheers.
Re: RCTools updates
Post by rray » 29 Jun 2013, 13:50
Oh of course all contributions are welcome! I'll build this in for the next release, maybe I'll wrap the multi select code around some other functions as well.
Cheers julca
Eugen
Re: RCTools updates
Post by Eugen » 26 Oct 2013, 07:24
thanks for this cool plugin! A beginner question, though:
how do you select, say, every 2nd edge of an edge loop?
I got it to work with polygons, but are edges working as well?
Eugen
Cacoman
Re: RCTools updates
Post by Cacoman » 12 Jan 2014, 18:12
Hello I am having this error. I know it is not related to the RCTools but for something I am doing wrong
# WARNING : RcTools: Symmetrize doesn't work when there is more than 1 symmetry axis.
How do I fix this to Flip topology to get a right shape.
Thx
To create something that does not exist, to exist.
Re: RCTools updates
Post by rray » 13 Jan 2014, 12:19
Hello,
The symmetrize function works only for 1 symmetry plane (axis was a bad choice of a word there)
if there's 2 or more planes it can't decide what side where to pick the information from.
it could also be that just one island of your model has more than 1 plane (like the eyeballs). Then it fails too.
_
edited my earlier answer because it was wrong
Reason: wrong
Cacoman
Re: RCTools updates
Post by Cacoman » 14 Jan 2014, 07:14
Oh, now I get it I was getting crazy to find what was the axis.
Thx a lot.
X-said
Re: RCTools updates
Post by X-said » 16 Dec 2021, 09:44
Hey guys, is there this plugin for xsi 2015?
Re: RCTools updates
Post by Hirazi Blue » 16 Dec 2021, 17:15
RcTools 5.3 should still work in Softimage 2015...
X-said
Re: RCTools updates
Post by X-said » 17 Dec 2021, 06:06
Hirazi Blue,hi
2014 and 2015 plugin is installed but does not work:(
Re: RCTools updates
Post by Hirazi Blue » 17 Dec 2021, 18:16
That's weird. On my install the custom filter settings do show up...
Re: RCTools updates
Post by wireframex » 18 Dec 2021, 17:12
Here
RCTools 5.3 is working perfectly
Phil
X-said
Re: RCTools updates
Post by X-said » 20 Dec 2021, 07:58
Thank you friends, everything is decided. When I reinstalled the plugin from under the admin (User win10)
