Eric Mootz just posted / sent this out:
http://www.mootzoid.com/plugin/emreader
emReader for Softimage
emReader
v.1.2750 updated Dec 21st 2017 — as of now, all of Eric's plugins including
this are available for free. emReader is a cache reader available for Softimage, Cinema4D, Maya, Modo and Fabric
Engine. It loads the cache files or parts of the cache file on-demand, resulting in
a low memory footprint.
From the Mootzoid site (archive): Supported file formats: RealFlow .bin Wavefront .obj Softimage's factory Polygonizer .emp2 Mootzoid .emp2 (compatible with emPolygonizer3) Mootzoid .mzd (compatible with emPolygonizer4 and emTopolizer).
Some features: Quick loading and rendering of indexed geometry cache files without the need to import them Animatable file index (e.g. to make timewarps or reverse the sequence) Loads motion vectors (scalable), normal vectors and texture coordinates, if available. Post-load effects: Fix double edges Fix non-manifold edges Close holes Push Smooth Thickness Triangulation Quadrangulation. The Fabric Engine version additionally supports several particle cache formats, for example: .bgeo (Houdini) .bin (RealFlow) .ptc (RenderMan) .mc (3ds max / Maya)
local backup:emReader-demoscenes.zip / emReader-xsiaddons.zip / emReader.pdf
author site: http://www.mootzoid.com (archive) / plugin page: /plugin/emreader (archive) / author @ vimeo / si-community thread
