kcsaba wrote:This is very handy tool! However I am not able to delete unfold props. Someone can confirm this? I am on 2013 sp1/ win7 x64.
Csaba
mCleaner and other tools
m|Cleaner 1.41 Updated July 2014. mCleaner is a »dashboard« full of functions for quickly
cleaning various sections of the current scene like unneeded clusters/properties/groups/material
libs/UVs/clips/layers etc. Each of mCleaner's functions may also be executed in »check
only« mode which only logs the objects that would be deleted. See this screenshot for a feature overview of an older version of mCleaner.
The 1.41 update adds the following (from the si-community thread): Undo, you can undo ! yay! Added Delete ICE trees, Partitions, and some other garbage Move unused textures to your backup folder option added (Only works with textures inside the picture folder) Everything has been reorganized in separated commands so you can customize your own tool some other minor changes, gui adjustments, etc. to make my life easier, and hopefully yours too.
The download page includes updated usage instructions (archive). Visit Martin's new company website http://www.skymill.co.jp (Japanese)
local backup: mCleaner.xsiaddon
Evenly Spaced Edges
Averages the edge lengths in a selected edgeloop or a closed edgeloop. This is a plugin
file; copy it to a Plugins directory of your choice (user, workgroup). It will add
a menu entry 'Evenly Spaced Edge' inside the MCP transform menu. Demonstration video
available here.
Based on Alan Fregtman's evenCurves.py script which does the same for curves. Loosely related to Andy Nicholas' popular »Taut« plugin.
local backup: mEvenlySpaceEdge.py (copy to a Plugins folder)
kcsaba
- Skype: csabakanal
Re: mCleaner and other tools
Sry Myara! 2 xsi ran in a same time when I installed the addon, I believe that was the problem!
csk
myara
I wrote a new version. It is still in "beta" test but so far it seems to work fine.
https://www.4shared.com/download/MAtvHj ... r.xsiaddon
If you have a previous mCleaner version you may need to uninstall it and delete it's preferences file before installing this one. I've included a few lines to make it easier to uninstall this version though.
I'm writing a manual for this so maybe in a few weeks I'll release it with a manual
Changes:
- Undo, you can undo ! yay!
- Added Delete ICE trees, Partitions, and some other garbage
- Move unused textures to your backup folder option added. (Only works with textures inside the picture folder)
- Everything was been reorganized in separated commands so you can customize your own tool.
- some other minor changes, gui adjustments, etc. to make my life easier, and hopefully yours too.
Now you have commands like :
mCleanObj (clean objects)
mCleanScn (clean scene parameters and things like that)
mCleanClusters ( clean clusters )
mRenCls ( rename clusters )
mCleanProps ( clean properties )
etc, etc.
You can just run it with the options you like and use the logged command to make your own button.
If you don't want to wait for my manual (that can take weeks because I write it in my free time) you can check the plugin comments.
Changes:
etc, etc.
M.Yara
yeah, the softimage essential tool is back !
We seriously need a repository for these kind of tools...
myara
Fixed a few bugs and added a help file. No major changes but in case you are interested :
http://www.skymill.co.jp/tools/Softimag ... leaner.htm
M.Yara
Neat! thanks for posting Martin
I noticed the explorer html menu for the english version doesn't work, might be on my side of the connection
myara
It works fine here with Chrome and IE 11. What problems are you having ? And what browser are you using ?rray wrote:Neat! thanks for posting Martin
M.Yara
csaez
- Skype: csaezmargotta
Sorry, the page you are looking for is not found.myara wrote:It works fine here with Chrome and IE 11. What problems are you having ? And what browser are you using ?
http://www.skymill.co.jp/tools/Softimage/mCleaner/mCleanerEN\___left.htm
myara
Oops. I'm not sure why that worked locally. Maybe an encoding issue.
Anyway it should be working now, at least it does with a few proxies I tried.
Gracias Cesar !
Gracias Cesar !
M.Yara
Thanks so much Myara!
Came in handy more than a few times, but for everyday use, I frequently use these MCleaner commands ;
And I know a few who used it mostly for this ;Rename Clusters
Rename all Polygon Clusters to their Material's Name with the option to add a Prefix and / or Sufix
Texture UVW
Rename all Texture Projection properties (Cluster, UV space property, UV Definition).
Freeze SRT
This freezes the object Scale, Rotation and Translation. Unlike the original Softimage Freeze option, this one also works with enveloped objects without breaking them.
working fine now, thanks for fixing!
tarkovsky
Anyone using this with succes in 2015?
mc_axe
yes is working finetarkovsky wrote:Anyone using this with succes in 2015?
tarkovsky
Thanks for reply. Simply couldn't get it working. Tested on different machine, where it is working fine. No clue why
myara
I don't know why it wouldn't work.
I'm not writing in Softimage lately and I don't remember exactly how I wrote mCleaner installer / uninstaller, but if the installer isn't working as expected you could try this manually:
1. Delete the preset file (mCleaner.Preset) from your preferences folder:
%USERPROFILE%\Autodesk\Softimage_2015\Data\Preferences
2. Unzip this file in your Addons folder:
%USERPROFILE%\Autodesk\Softimage_2015\Addons\
Or your Workgroup Addons folder.
http://skymill.co.jp/tools/Softimage/mC ... leaner.zip
Or Try installing it again:
2. Download the xsiaddon file and install it again
http://skymill.co.jp/tools/Softimage/mC ... r.xsiaddon
BTW, there was a problem with the delete normal clusters (sample clusters) option.
I fixed it some time ago, don't remember exactly when but this version should be working fine.
M.Yara
tarkovsky
Thanks myara.
The installer works, and I also get the new menu option under "edit", but nothing happens when I invoke the plugin.
I can select and object and invoke the GUI property on an object, but nothing happens when I press RUN.
On other PC it all works fine, and removing normals was exactly what I needed, so thank you for this awesome tool!
t
t
myara
I don't know why it doesn't work. Do you have any error message?
Run it, open the Script Editor and paste the log here.
It should say something like this:
Check also the Plugin Manager.
// mCleaner 1.44 | ObjCleaner
// INFO : [sample.body] Texture_Coordinates_AUTO has been deleted
// INFO : [sample.body] EnvelopWeightCls2 has been deleted
// INFO : [sample.body] EnvelopWeightCls1 has been deleted
// INFO : [sample.body] EnvelopWeightCls has been deleted
// INFO : [sample.body] Edge_AUTO has been deleted
// INFO : [sample.body] Envelope Cluster has been renamed to [EnvelopWeightCls]
// INFO : [sample.body] ObjectAttribute has been deleted
// INFO : [sample.body] G.Approximation Angle changed to 180
// mCleaner | ObjCleaner : All tasks finished
mCleanerObj("ccf000_01_sample.body", false, true, true, true, false, true, false, false, false, true, true, true, true, true, true, null, null, true, true, true, true, "Texture_Coordinates_AUTO", "Texture_Projection", "Texture_Projection_Def", true, 0, 0, "EnvelopWeightCls", "Envelope_Weights", "Unfold", "Crosswalk", "MayaAttributes", true, true, true, true, false, true, false, true, 180, false, 0, 0, 0, false, false, true, 2, 1);
M.Yara
