RTCompound: Architectural Framebuffers Compound
Architectural FramebuffersAuthor: Jason Wells
This is a rendertree compound that splits up the Architectural Shader over ALL the framebuffer channels. Something similar has been done but I thought I'd try it myself anyway.
What I've also done is created a couple of simple scripts that set up ALL the required channels so that all you need to do is plug in the RM_Architectural Splitter and hook it up like a normal mia_architecture node and your ready to render out a series on floating or non-floating point channels.
Look at the forum thread for more details and usage instructions.
local backup: RM_Architectural Splitter.xsirtcompound
redmotion
Post by redmotion » 10 Oct 2009, 20:13
RM_Architectural Splitter.zip
Lastly, I've left the names of the mia parameters as they are so its easier to cross reference with the param names in Mental Images Architectural Shaders manual. (See page 44 for comp setup)
1.Add all the channels to the scene with:
CreateRenderChannel "Diffuse_Result", siRenderChannelColorType
CreateRenderChannel "Diffuse_Raw", siRenderChannelColorType
CreateRenderChannel "Diffuse_Level", siRenderChannelColorType
CreateRenderChannel "Spec_Result", siRenderChannelColorType
CreateRenderChannel "Spec_Raw", siRenderChannelColorType
CreateRenderChannel "Spec_Level", siRenderChannelColorType
CreateRenderChannel "Refl_Result", siRenderChannelColorType
CreateRenderChannel "Refl_Raw", siRenderChannelColorType
CreateRenderChannel "Refl_Level", siRenderChannelColorType
CreateRenderChannel "Refr_Result", siRenderChannelColorType
CreateRenderChannel "Refr_Raw", siRenderChannelColorType
CreateRenderChannel "Refr_Level", siRenderChannelColorType
CreateRenderChannel "Tran_Result", siRenderChannelColorType
CreateRenderChannel "Tran_Raw", siRenderChannelColorType
CreateRenderChannel "Tran_Level", siRenderChannelColorType
CreateRenderChannel "Indirect_Result", siRenderChannelColorType
CreateRenderChannel "Indirect_Raw", siRenderChannelColorType
CreateRenderChannel "Indirect_Post_AO", siRenderChannelColorType
CreateRenderChannel "AO_Raw", siRenderChannelColorType
CreateRenderChannel "Add_Result", siRenderChannelColorType
CreateRenderChannel "Opacity_Result", siRenderChannelColorType
CreateRenderChannel "Opacity_Raw", siRenderChannelColorType
CreateRenderChannel "Opacity", siRenderChannelScalarType
2a. Either add all the floating point channels using:
Beauty = diffuse_level * (diffuse_raw + (indirect_raw * ao_raw)) +
spec_level * spec_raw +
refl_level * refl_raw +
refr_level * refr_raw +
tran_level * tran_raw +
add_result
Set oPass = GetCurrentPass
CreateFramebuffer "Passes." & oPass.Name, "Diffuse_Level"
SetValue "Passes." & oPass.Name & ".Diffuse_Level.Format", "exr"
SetValue "Passes." & oPass.Name & ".Diffuse_Level.BitDepth", 21
CreateFramebuffer "Passes." & oPass.Name, "Diffuse_Raw"
SetValue "Passes." & oPass.Name & ".Diffuse_Raw.Format", "exr"
SetValue "Passes." & oPass.Name & ".Diffuse_Raw.BitDepth", 21
CreateFramebuffer "Passes." & oPass.Name, "Indirect_Raw"
SetValue "Passes." & oPass.Name & ".Indirect_Raw.Format", "exr"
SetValue "Passes." & oPass.Name & ".Indirect_Raw.BitDepth", 21
CreateFramebuffer "Passes." & oPass.Name, "AO_Raw"
SetValue "Passes." & oPass.Name & ".AO_Raw.Format", "exr"
SetValue "Passes." & oPass.Name & ".AO_Raw.BitDepth", 21
CreateFramebuffer "Passes." & oPass.Name, "Spec_Level"
SetValue "Passes." & oPass.Name & ".Spec_Level.Format", "exr"
SetValue "Passes." & oPass.Name & ".Spec_Level.BitDepth", 21
CreateFramebuffer "Passes." & oPass.Name, "Spec_Raw"
SetValue "Passes." & oPass.Name & ".Spec_Raw.Format", "exr"
SetValue "Passes." & oPass.Name & ".Spec_Raw.BitDepth", 21
CreateFramebuffer "Passes." & oPass.Name, "Refl_Level"
SetValue "Passes." & oPass.Name & ".Refl_Level.Format", "exr"
SetValue "Passes." & oPass.Name & ".Refl_Level.BitDepth", 21
CreateFramebuffer "Passes." & oPass.Name, "Refl_Raw"
SetValue "Passes." & oPass.Name & ".Refl_Raw.Format", "exr"
SetValue "Passes." & oPass.Name & ".Refl_Raw.BitDepth", 21
CreateFramebuffer "Passes." & oPass.Name, "Refr_Level"
CreateFramebuffer "Passes." & oPass.Name, "Refr_Raw"
CreateFramebuffer "Passes." & oPass.Name, "Tran_Level"
SetValue "Passes." & oPass.Name & ".Tran_Level.Format", "exr"
SetValue "Passes." & oPass.Name & ".Tran_Level.BitDepth", 21
CreateFramebuffer "Passes." & oPass.Name, "Tran_Raw"
SetValue "Passes." & oPass.Name & ".Tran_Raw.Format", "exr"
SetValue "Passes." & oPass.Name & ".Tran_Raw.BitDepth", 21
CreateFramebuffer "Passes." & oPass.Name, "Add_Result"
SetValue "Passes." & oPass.Name & ".Add_Result.Format", "exr"
SetValue "Passes." & oPass.Name & ".Add_Result.BitDepth", 21
2b. Or the simpler non-floating point setup:
Beauty = diffuse_result + indirect_result + spec_result +
refl_result + refr_result + tran_result +
add_result
CreateFramebuffer "Passes." & oPass.Name, "Diffuse_Result"
CreateFramebuffer "Passes." & oPass.Name, "Indirect_Result"
CreateFramebuffer "Passes." & oPass.Name, "Spec_Result"
CreateFramebuffer "Passes." & oPass.Name, "Refl_Result"
CreateFramebuffer "Passes." & oPass.Name, "Refr_Result"
CreateFramebuffer "Passes." & oPass.Name, "Tran_Result"
redmotion
Re: RTCompound: Architectural Framebuffers Compound
Post by redmotion » 10 Oct 2009, 20:19
This is the Toolbar for containing the scripts above.
Architectural Channels Scripts.zip
maxmancl
Post by maxmancl » 11 Oct 2009, 10:59
Very good, thanks.
redmotion
Post by redmotion » 11 Apr 2010, 20:37
Updated for 2011 using the new (faster) mia_x material (quite roughly implimented as some parameters don't seem to have any use. All new parameters have been added to a PPG group called "Other" in Additional Options tab.)
Due to a RT limitation, the light list cannot be exposed in a compound, so you'll have to go into the compound and add them manually. I've therefore set the default option to "ignore the list".
Very little testing has been done but the scripts here seem to work fine with it. AO seems to render fine too, but I've noticed some errors regarding AO appearing in the script editor.
Please test and report any issues! Thanks.
RM_Architectural Splitter_2011.zip
Post by luceric » 12 Apr 2010, 18:25
mia_material_x is in Softimage 2011,
it's called "Architectural (multi-out)"
irakli_san
Post by irakli_san » 06 Jul 2010, 16:49
Thanks for shearing
found a mistake in script. after createframebuffer for refraction pass in setvalue line. its refl_raw and must be refr_raw
oh! and adding "apply RM_ArchMaterial to selection" button to your toolbar would be great idea
p.s.
any idea how to easily toggle between "Render Channels" in render region?
