Edge Shading
Edge ShadingAuthor: Reinhard Claus
A render tree compound that renders worn/chipped off/colored/funny edges. Mental Ray only. But built from only a few factory nodes, so it should be fairly easy to reproduce this in other renderers.
The letters in the thumbnail were rendered by plugging the node's color output into a phong diffuse port, and into a bump map node at the same time. Let me know if you have issues/ideas about this shader.
local backup: Edge Shading.xsirtcompound
Edge Shading
Post by rray » 27 Mar 2013, 01:13
Mental Ray only. But built from only a few factory nodes, so it should should be fairly easy to reproduce this in other renderers.
Letters above rendered by pluggin node's color output into a phong diffuse port, and into a bump map node at the same time. Let me know if you have issues/ideas about this shader.
Re: Edge Shading
Post by Bullit » 27 Mar 2013, 01:16
Looks great. Thanks.
Re: Edge Shading
Post by ActionArt » 27 Mar 2013, 01:25
Nice one!! That looks to be very useful. Thanks for posting that! :-bd
Re: Edge Shading
Post by ActionArt » 08 May 2013, 15:08
I'm really liking this, wish I had it 10 years ago! Very useful.
Re: Edge Shading
Post by rray » 08 May 2013, 16:48
Thanks for your feedback ActionArt
Btw just noticed there's a missing connection inside the compound when using ambient occlusion mode:
It should go from "Maximum1" to the max_distance port of the "ambient_occlusion" at the top
This caused inner corners not to get textured properly
(top post updated)
Re: Edge Shading
Post by ActionArt » 08 May 2013, 17:24
sirdavid32
Re: Edge Shading
Post by sirdavid32 » 16 May 2013, 04:55
I´m using softimage 2012. I don´t get the effect when I connect it to the difuse input of a phong shader. I would like to get the black line. I used the color black but no results.
mixepix
Re: Edge Shading
Post by mixepix » 20 May 2013, 08:36
Looks like an awesome compound, thanks!
http://vimeo.com/mikaelpettersen
