DW_AddParticleToModelsAndInstances
Add Particles to Models and InstancesAuthor: David Wigforss
This compound is in response to a thread on XSIBase. You can add a particle attached to each object in models/instances. Create a group containing the objects inside of the model. (ie. ObjectGroup) Create a group containing the model and instances. (ie. InstanceGroup). I tested animating the position and rotation of the objects, model, and instances.
local backup: DW_ColorBlendModes.xsicompound
dwigfor
Post by dwigfor » 17 Jan 2012, 10:22
This compound is in response to a thread on xsibase. You can add a particle attached to each object in models/instances.
* Create a group containing the objects inside of the model. (ie. ObjectGroup)
* Create a group containing the model and instances. (ie. InstanceGroup)
-David Wigforss
Hopefully it works for you; I take no responsibility if it doesn't....
