Instances to Mesh
Instances to MeshAuthor: Grahame Fuller
Here's a set of compounds for converting an instance particle cloud to a polygon mesh. You can transfer UVs, etc. It's designed to work when you use a group for the instance shapes. Note that if you are using a small number of shapes (small enough that you can reference each one directly), then Guillaume Laforge's compounds are probably faster. You can get them here.
Usage Notes: To use, put Convert Instances to Mesh in an ICE tree on an empty mesh. It works only with the »self« object. You also need to store the shape index on the point cloud and reference it in the compound's ppg. To transfer attributes, attach one of the Transfer compounds to the Execute port — there's one for each component type.
If you transfer the MaterialIDs, then you can use the Copy Materials checkbox. This works only if all objects in the group have identical Materials arrays. The transfer is based on finding locations on the group geometry, so it's best to move the instance masters apart if they overlap. It uses the 2013 version of »Build Array from Set« which supports topology-type attributes. To use it with Softimage v2012, you'll need to replace it with »Build Array from Per Point Data«.
local backup: Convert Instances to Mesh.2.0.xsicompound Convert Instances to Mesh.2.0.xsicompound Transfer Edge Attribute.xsicompound Transfer Polygon Attribute.xsicompound Transfer PolyNode Attribute.xsicompound Transfer Vertex Attribute.xsicompound
Re: Instances to Mesh
Post by rray » 06 Apr 2016, 21:24
here's an update to the Convert Instances to Mesh.2.0 compound
It should fix the uv border issue, the node lookup point is shifted a 0.00001 fraction of the adjecent edges lengths, that way the right polyon node is picked.
Optionally the old behavior can be restored (uncheck "apply node fix" in the compound)
SPJ
Post by SPJ » 07 Apr 2016, 10:05
FYI I've just had the file opened in SI 2015 and the materialID problem is gone. It looks like a problem/bug with SI 2014. I'm going to rebuild my scene tonight, hopefully using both 2015 and the new compound I'll achieve the goal of procedurally generating split face tiles!
