Procedural Topo Pack
Updated Feb 2013 Various ICE topology compounds that I made for last months. Fully compatible with
SI 2012. After installation they can be found in Context, Interactive and Topology
categories of the Tool tab menu.
Contents: Build Array from Set Node (for Softimage 2012), Array to Edge Set, Array to Polygon Set, Array to Sample Set, Array to Vertex Set, Build Array per Edge, Build Array per Point, Build Array per Polygon, Build Array per Sample, Delete Topology, Disconnect Islands, Get Edge Position, Set Edge Position, Get Polygon Position, Set Polygon Position, Polygon Index to CAV, Vertex Index to CAV, Select Polygons Interactive, Slice to Pieces, To per Edge, To per Point, To per Polygon, To per Sample
The recent updates from the si-community thread linked below include: Greeble, Slice on Cubes, Extract Polygon Island, Split Edge Equally
local backup: ProceduralTopoPack.zip
iamVFX
Re: Procedural Topo Pack
Thanks Constantine for the topo pack.
iamVFX
Stop thanking me, everybody, show the pictures and ask questions
Maybe a dumb question , but what is the true node there, i don't remind it.
iamVFX
It's just a limitation of old version, I fixed that already. If you left Clamp parameters at False value all the polygons would scaled and transform. Bu they're not now.Bullit wrote:Maybe a dumb question , but what is the true node there, i don't remind it.
Also Extrude Islands returns proper Top and Side clusters now, please redownload the topo pack and test it if you have a chance
I think i am too green in ICE for this, i thought node "to per point" was to change for example context from polygons to per point but i was unable to do it.
iamVFX
To change context from polygons to vertices you have to build array from set of PolygonToVertices attribute and use "Array to Vertex Set" compoundBullit wrote:I think i am too green in ICE for this, i thought node "to per point" was to change for example context from polygons to per point but i was unable to do it.
Thanks. I'll go now studying how changing context works.
iamVFX
Greeble. Well, sort of, some of the features are missing (instancing on top of extruded polygons), they were cut for performance reasons, but still.
Pocedural Topo Pack is updated, download it first.
iamVFX
Sometimes you should feed a constant set of polygons to make Extrude Islands work. It can be done by building array from polygons you want to extrude and converting the resulting array to set via Array to Polygon Set compound, like so:
[rimg=800]http://img688.imageshack.us/img688/794/9d8e5b334523418ea429bb2.png[/rimg]
iamVFX
Iterative fracture example with use of Slice Topology node.
Procedural Topo Pack is updated!
This looks very nice, could you do it just partially?
iamVFX
SureBullit wrote:This looks very nice, could you do it just partially?
[rimg=521]http://i.imgur.com/Np8Qy.png[/rimg]
nice!
thanks for all these goodies!
Does it needs Momentum?
iamVFX
No, you should remember that is not a boolean operation, the inner bunny generated automatically by the inverse extrusion, you can check how it works in a compoundBullit wrote:haha! curious about the bunny inside the bunny did you made it on propose?
Of course not, you can use it for other types of effects, if you find anyBullit wrote:Does it needs Momentum?
