Trying to get a CAV map blur...
Vertex Blur Plus PlusAuthor: Rob Chapman
This compound generates a blurred vertex color map from an input vertex color map. The input color map must be set inside the compound. See this post for details. Has parameters for strength and distance.
Rob posted this in a si-community thread started by Pete, asking for a way to blur vertex colors using ICE.
local backup: Vertex_blur_plus_plus.xsicompound
Tekano
Re: Trying to get a CAV map blur...
Post by Tekano » 13 Jul 2012, 19:52
hey Pete
is there any reason you need it to be on the one CAV map? there are a few layers of context you have to jump into and out of in order to get this to work with them so get that there are a lot of red nodes when using CAVs in ICE without understanding the context correctly. I could appreciate there may be issues with a live CAV map that has been painted by hand then blurring it in ICE, what happens when you paint again are you painting on the blurred one or the original then its blurred again..?
So yes for simplicity and sanity I keep it separate, a live paint version and a post blurred one. In ICE there is a difference in what a vertex color sample is and a per point attribute data like 'color' so its not so easy to grasp, but anyways I somehow re-wired this to work with only one vertex map and if you paint on same map the ICE tree blurs it afterwards , you just have to be careful with the stack inside the vertex map - as long as the ice tree is last after the the painting then it should work ok, but there is no guarantees of safety when painting
AND you still have to go inside the compound to direct the 'closest sample' location to point to the same vertex color map as you plug in. this is the bit I cannot get to work either, Im guessing because its part of a location so 'in name' does not work :)
Pete
Post by Pete » 14 Jul 2012, 23:25
Hey thanks Tekano,
Okay, I get it now 2 cav maps would definitely be better. :)
I guess I was trying to simplify things but I can see how that would actually complicate things!
I'll have to figure out how to make the name plug in work though, I've run into this a bit with ice. Another thread maybe :)
Thanks for the help
Pete
