Topo Changes on Referenced Models / Workaround
February 14th, 2007 by Helge Mathee - Viewed 4908 times -
As in the current implementation of the referenced models it is not allowed to do topological changes on top, here’s a workaround which has proven to work well in production:
Basically, for a flexible workflow, I use scripted operators to copy the pointcloud from a referenced object to a local copy in the scene, to deformations on top, and then copy it back into the referenced model. This requires the geometry to exist twice, in the ref model. However, a more complex example could be to use ONE operator to do both copies, this way you wouldn’t need two meshes inside the ref model.
For the sake of simplicity, here’s the example with a simple pointcloud-copy scripted operator in JScript. Just run this in an empty scene.
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
var myProject = ActiveProject.path;
// create the model
NewScene(false,false);
// create two cylinders
var source = CreatePrim("Cylinder", "MeshSurface", null, null);
var target = CreatePrim("Cylinder", "MeshSurface", null, null);
SetValue("cylinder1.Name", "cylinder_out", null);
FreezeObj("cylinder,cylinder_out");
// create a skeleton
Create2DSkeleton(0, 4, 0, 0, 0, 1, 0, 90, 0, 4, null, null);
AppendBone("eff", 0, -4, 0, null);
ApplyFlexEnv("cylinder;root,bone,bone1,eff", null, 2);
// apply the copy op to the second cylinders
createCopyPosOp(source,target);
DeselectAll();
// create an empty model
CreateModel();
ToggleVisibility("cylinder");
// put all objects (cylinders and chains) below the model
ParentObj("model","cylinder_out,cylinder,root");
// export the model to the current project
ExportModel("Model", myProject + "\\Models\\ref_geo.emdl");
// create the scene with a referenced model
SICreateRefModel(myProject + "\\Models\\ref_geo.emdl");
// create the local meshcopy
var result = addLocalMeshCopy(
				Dictionary.GetObject("ref_geo.cylinder"),
				Dictionary.GetObject("ref_geo.cylinder_out"));
// do a deform on top
ApplyOp("Push", result+".pnt[0,2,3,7,8,12,13,17,18,22,23,27,28,32,33,37,38]");
SetValue("cylinder_local.polymsh.pushop.ampl", 1 );
SelectObj("ref_geo.eff");
// the function to create a mesh copy
function addLocalMeshCopy(source,target)
	// retrieve the mesh data
	var meshData = source.ActivePrimitive.Geometry.Get2().toArray();
	var points = meshData[0].toArray();
	var polies = meshData[1].toArray();
	// create a new mesh
	var newMesh = ActiveSceneRoot.AddPolygonmesh(points,polies,source.name+"_local");
	// copy the point positions from the enveloped
	// mesh to the local copy
	createCopyPosOp(source,newMesh);
	// turn off the original copy op
	SetValue(target+".polymsh.copyPos.mute", true);
	// now copy the point positions from the local copy to the final output
	createCopyPosOp(newMesh,target);
	return newMesh;
// the function to create the point position copy operator
function createCopyPosOp(source,target)
	// create the op
	var op = XSIFactory.CreateScriptedOp( "copyPos", copyPos_Update.toString(), "JScript" );
	// create two ports for in and out and connect it
	op.AddOutputPort( target.ActivePrimitive );
	op.AddInputPort( source.ActivePrimitive );
	op.Connect();
// the update code for the point pos copy operator
function copyPos_Update(ctxt,outMesh,inMesh)
	var pos = inMesh.value.geometry.points.positionarray.toArray();
	outMesh.value.geometry.points.positionarray = pos;
3 Responses to “Topo Changes on Referenced Models / Workaround”
  1. Daniele Niero says:
    Hi Helge,
    I’ll try this for sure but I got a question for you :)
    you said:
    “As in the CURRENT implementation of the referenced models it is not allowed to do topological changes…”
    Does that mean you are working for make it possible in the future? it would be great!
  2. Helge Mathee says:
    I can’t comment on that, sorry.
  3. Daniele Niero says:
    :) I understand…
    Thank you anyway
