Kraken Windows 10
Posted: 12 Sep 2016, 17:37
If you try to install Kraken
after having installed the alternative PyQtForSoftimage and the alternative PySide, as I described here on Windows 10...
So you'll have to edit line 121 of "kraken_si.py" to read
Hat-tip: EricTRocks.
(Quoted from here)you'll need to edit the Kraken plugin file (kraken_si.py) on line 121 or so and remove the long() that is wrapped around the sianchor variable. That would be my first step.
sianchor = Qt.wrapinstance(sianchor, QWidget)
