Page 5 of 6
Re: SiScatter
Posted: 17 Aug 2016, 09:05
by yashugan
I'm sorry but there is no way. No one have be able to make it work?
Thank you!!!!!
Re: SiScatter
Posted: 17 Aug 2016, 09:56
by Pooby
You don't write the name of the image file. You just access the texture map that contains the image.
Re: SiScatter
Posted: 17 Aug 2016, 10:30
by yashugan
Can you please do a example? I tryed this too, but i didn't workkk
thank!
Re: SiScatter
Posted: 17 Aug 2016, 12:12
by julca
Hello @yashugan !
Thank you for your comment !
About texture map, I notice that you just need to recreate the "Get Data" node inside the "siScatter _ Filter by Texture Map" compound : cf. screenshot
I don't understand why for now, I need to investigate more..
Re: SiScatter
Posted: 17 Aug 2016, 12:22
by julca
A way more simple solution :
Just disconnect the "siScatter _ Emitter" node, and that will be ok (it may make a double reference that create a sort of path error).
Re: SiScatter
Posted: 17 Aug 2016, 14:05
by yashugan
I'm sorry but i don't work:(
There are possibility to fix your interface with a more direct "texture " picker to filter the objects? Thank!
Re: SiScatter
Posted: 17 Aug 2016, 15:31
by julca
yashugan wrote:I'm sorry but i don't work:(
Yes, I will update the addon, but in the meantime it may work !
cf. gif animation for the full explanation step by step (sorry for the gif size/compression..)
Let me know if you still have problem.
Re: SiScatter
Posted: 17 Aug 2016, 16:20
by yashugan
ho yeah!!!!!!!!!!!!!!!!!!!!!!!! thank you!!!!!!!!!!!!!!!
this will help my work 1000 times!!!!!!!!!!!
Fantastic! and thank again for the patience with me!!
Re: SiScatter
Posted: 20 Aug 2016, 11:20
by julca
Hello !
I've just upload a new version of siScatter (1.6) with :
- - New alignment options based on emitter's border edge :
- Cutoff distance
Orientation offset with variance
- A new option in "Filter C" tab :
- an accurate Neighbors delete with distance option
- Bug correction on Texture Map
Gif Quick Demo A
Gif Quick Demo B
Re: SiScatter
Posted: 20 Aug 2016, 13:42
by druitre
Thanks Julca, this has been one of my favourite collections of nodes!
Re: SiScatter
Posted: 20 Aug 2016, 14:53
by jonmoore
Thanks Julca. Such a great scattering toolset.
Re: SiScatter
Posted: 20 Aug 2016, 16:47
by yashugan
Fantastic! i'm really happy! i'm doing landscapes just in those days, and your scatter is simply awesome! thank!!!!!!!!!!
Re: SiScatter
Posted: 20 Aug 2016, 17:45
by julca
Thank you all for your comments !
I'm glad that you find this tool useful.
Re: SiScatter
Posted: 20 Aug 2016, 18:02
by yashugan
Apologize me, but i can't find any more the other Randomize, have you removed them?
Re: SiScatter
Posted: 20 Aug 2016, 18:41
by julca
yashugan wrote:Apologize me, but i can't find any more the other Randomize, have you removed them?
No problem, that's probably because you need to rebuild a new version of siScatter from scratch.
Let me know.
Re: SiScatter
Posted: 20 Aug 2016, 21:30
by yashugan
Ops, it seem that's are missing, apologize me, i maded a bad analize of the result.
Or probably i'm doing somthing wrong again...
any way i can try to manage:)
thank again! by
