Lock Points Position
Posted: 06 Sep 2013, 11:32
I just wrote an script to lock points and I though it may be useful for some of you.
It's based on a friend (ymt3d) Ice Tree, who made that ICE based on a crappy script I wrote
I just wrote his version to make it automatic. And it is way faster than the script I wrote, and don't want to use anymore.
https://dc685.4shared.com/download/1hnF ... intsICE.py
Lock points:
select your points, and run.
It will create a point cluster with the selected points and lock the position of the points that are in that cluster.
Unlock:
Select your object and run.
It will freeze the ice tree and delete the cluster.
Warning : Since it freezes the ICE tree, everything under it will be gone.
How to install it:
It's a script. Run it from your script editor, or better, create a button in a shelf or toolbar.
Since it is Python, you'll need Python to be installed.
It's only been tested in SI 2012, but newer SI should be ok.
2010, I'm not sure.
Lock points:
Unlock:
How to install it:
2010, I'm not sure.
