PolyMesh Duplicator v1.2.1
PolyMesh Duplicator
V1.2.1 Nassos' recreation of Guillaume Laforge's addon (see video). Creates multiple procedural copies of a mesh which can be accessed from an ICE
tree. Just like Houdini's Copy/Duplicate SOP. See video tutorial on vimeo, and for more details see the si-community discussion link.
local backup: PolyMeshDuplicator1.2.1.zip
author site: n/a / si-community thread
********Update
v1.1: Added a command to separate the duplicated mesh into multiple objects.
The stack of the duplicated mesh must NOT be frozen (it needs the PolyMeshDuplicator operator).
Right now clusters, animation and uv coords are completely ignored.
The "separate" command is meant to be fast (hopefully someone will also make it feature complete)
because all the other scripts i found on the net are way too slow.
The commands have been moved to the "Modeling > Modify > PolyMesh" menu.
Added a "Move to 3D Grid with CopyID" ICE compound, to help make 3D Grid formations.
Source code is included.
v1.0 info:
Makes procedural duplicates of a polygonMesh object that can be manipulated in ICE.
I saw Guillaume Laforge's op here
http://www.vimeo.com/groups/ice/videos/6996197
and since i couldn't find his online, i decided to make my own.
Use it at your own risk.
For XSI 7.01 x86-x64 windows
Posted a video tutorial of it here:
http://www.vimeo.com/7218396
Update: Added "Random with CopyID", "Transform to PointCloud with CopyID"
and "Move to 3D Grid with CopyID" ICE compounds
Local copy can be found here: http://www.si-community.com/download/pl ... v1.2.1.rar
Usage:
Now you no longer have to open up an ICE tree to get it working.
To use "PolyMesh Duplicator for Pointcloud":
- Select the mesh that is used as instance shape.
- Choose Modify->Poly.Mesh->PolyMesh Duplicator for Pointcloud
- Pick the pointcloud to which the geometry should be matched.
- In the "Copies" field of the PolyMeshDuplicator operator, enter the
number of particles.
If you do not know the number of particles, you can
find it out by choosing View->Scripting->SDK Explorer. Then select the
pointcloud, choose "Object Details" and scroll down until you see: "Number of particles: xxxxx"
v1.0 info:
Usage:
- Attachments
- PolyMeshDuplicator Addon v1.2.1.rar
- (61.39 KiB) Downloaded 1316 times
- CopyID Compounds.rar
- (4.18 KiB) Downloaded 1103 times
- PolyMeshDuplicator Addon v1.1.rar
- (40.17 KiB) Downloaded 1092 times
Re: PolyMesh Duplicator
that looks to be quite handy!
Thank you for sharing it, nassosy, and thank you for
generously sharing your other recent ICE goodies as well!
whats the chances you would make the source available?
DL it from above.
thanks! more of this open shared knowledge will only help bring more customizations to our community
Re: PolyMesh Duplicator v1.1
any chance you're gonna compile it for softimage 2010 x64 ?
i tried and doesnt work
thanks for sharing !
I only have 2010 SP1 x64 and it works
If you try to import scenes from previous releases (ex. 7.01),
you have to re-apply the operator,
because SI doesn't seem to properly connect it
(don't know why)
I attached a sample scene
(the forum doesn't allow uploads > 256kb,
so it is split )
(don't know why)
so it is split )
- Attachments
- PolyMesh_Duplicator 2010 sample 01.part03.rar
- (86.34 KiB) Downloaded 779 times
- PolyMesh_Duplicator 2010 sample 01.part02.rar
- (256 KiB) Downloaded 835 times
- PolyMesh_Duplicator 2010 sample 01.part01.rar
- (256 KiB) Downloaded 841 times
Thanks for your great tool!!
Is it possible to reproduce this effect with your addon?
http://vimeo.com/groups/ice/videos/6999806
http://vimeo.com/groups/ice/videos/6996197
And I would like to make, for instance, random distribution of these spheres, is it possible somehow.
Thanks in advance!
Thanks in advance!
I added some compounds to help you make it happen,Robert_XSI wrote:Thanks for your great tool!!
Thanks in advance!
DL from above.
- Attachments
- PolyMesh Ramdom.png (172.11 KiB) Viewed 21746 times
Thanks Nassosy for you reply and the compound.
It is such a great tool, so as ICE. I am only a newbie, but sucking in ICE info..
Unfortunately I rather thought about the other movie, this one
http://vimeo.com/6999806
Can I attach your duplicated objects to another cloud points, just like in the above movie?
Highly appreciate you contribution to this small, hopefully fast-expanding community.
THX
THX
That's what the "Transform to PointCloud with CopyID" compound does,Robert_XSI wrote:
plug the point cloud to the geometry port and that's it.
Hi nassosy,
Thank you for sharing your addon, it's very useful!
I would like to modify your script a little to automatically plug in a pointcloud into the "Transform to Pointcloud" node. Do you mind if I re-publish your modified work here?
Be my guestSquizmek wrote:Hi nassosy,
Ok, now you can convert your pointcloud to a polymesh directly without having to open any ICE-trees!
I have also added a GNU General Public License so this addon remains free. I hope this is ok with you
I simply added the following functionality:
New function "PolyMesh Duplicator for Pointcloud"
Thanks again for your great Addon!
- Attachments
- PolyMeshDuplicator Addon v1.2.rar
- (61.08 KiB) Downloaded 517 times
v1.2.1
I corrected some bugs i found to the 1.2 version you posted.
Changed it, so it automatically sets the Copies to the number of particles there are at the current frame,
and renamed the "Transform Geometry to Pointcloud" compound to "Transform PmDuplicated to Pointcloud"
to avoid user confusion.
just uninstall/delete the old addon and install the new one.
- Attachments
- (61.39 KiB) Downloaded 372 times
I personally doubt that anyone would pay for
such a simple plugin like this.
Users browsing this forum: No registered users and 21 guests
