AD subscription
azurecgi
Re: AD subscription
Post by azurecgi » 14 Nov 2012, 14:57
xsisupport wrote:I don't understand. Can you point me to the VRay documentation that says you can render with xsibatch -processing ?
thx
My understanding was:
A processing license allows you to run xsibatch without taking a Batch license.
Batch licenses are for rendering with xsibatch, whether it is VRay or mental ray or Arnold...or is VRay different somehow?
Just repeating what I was told by a reseller when asking how I can purchase more batch licenses to use with Vray. I really, really don't see the logic in making me purchase another copy of Softimage just so I can render on 5 more machines (I was told this is the only way to obtain more XsiBatch licenses!!!!!!)
Letterbox
Re: AD subscription
Post by Letterbox » 14 Nov 2012, 15:10
xsisupport wrote: This is exactly why the limit was changed to four satellite machines :-)
http://xsisupport.com/2010/12/08/satell ... licensing/
Only satellite was mentioned, the batch/render nodes are the same too? So it's all the same now main pc, satellite, render nodes all use as many cpu/cores as that machine has, it's all per machine now?
Thanks too Stephen - feels like everything on that blog - somewhere :)
Letterbox
Re: AD subscription
Post by Letterbox » 14 Nov 2012, 15:18
thx
azurecgi, not to distract from your question, but to compliment it, ask the dealer / chaosgroup if vray renderer uses it's license per machine or per cpu. As if you have a dual xeon box it might only take 1 license.
Re: AD subscription
Post by xsisupport » 14 Nov 2012, 15:20
Batch is per machine. xsibatch will use everything it can on the local machine.
// Steve Blair
Re: AD subscription
Post by xsisupport » 14 Nov 2012, 15:22
thx
If you're rendering with xsibatch, then yes, you would need to buy another network license.
Batch licenses aren't sold separately (a network license could be viewed as a six-pack, if you don't need to run Softimage interactive, you can use that license as sixth batch).
That's my understanding. I don't understand why VRay sells 10packs in that case???
// Steve Blair
Re: AD subscription
Post by Daniel Brassard » 14 Nov 2012, 16:25
I am a visual person, I wish I had a graphic like this one that explained Soft licensing, advantages and disadvantages for each options (SLM, Network, batch, satellite, and so on).
This thread is turning into a good refresher on what we get with Soft.
Re: AD subscription
Post by Daniel Brassard » 14 Nov 2012, 16:53
Bellsey or Stephen, can you clarify:
A Network(NLM) license of Softimage will gives you all that you get with Standalone, plus:
5 x Softimage Mental Ray Batch/Render nodes for network rendering
In addition, each install of Softimage Batch can also use up to four (4) satellite CPUs for distributed tile rendering.
I have a NLM license, does it means 5 x MR Batch/render and 4 x Satellite Render or
5 x MR Batch/render and 20 x Satellite Render?
Re: AD subscription
Post by xsisupport » 14 Nov 2012, 17:00
Daniel Brassard wrote:Bellsey or Stephen, can you clarify:
You get one license for XSI.exe and five licenses for xsibatch.exe.
Each instance of XSI.exe or xsibatch.exe can use up to four satellite machines.
Re: AD subscription
Post by xsisupport » 14 Nov 2012, 17:20
Daniel Brassard wrote:I am a visual person, I wish I had a graphic like this one that explained Soft licensing, advantages and disadvantages for each options (SLM, Network, batch, satellite, and so on).
Yup, back in the early days we had a graphic somewhat like that on the wiki. It's gone from the web now, but it looked like this:
// Steve Blair
steven07
Skype: stevenpalomino
Re: AD subscription
Post by steven07 » 14 Nov 2012, 17:28
Pardon my ignorance... but what's the difference between interactive rendering and batch rendering?
So from what I understand I can use boxes that have 6 cpu cores if I want but it's only up to 4 extra boxes (including the master)?
Re: AD subscription
Post by xsisupport » 14 Nov 2012, 18:05
steven07 wrote:Pardon my ignorance... but what's the difference between interactive rendering and batch rendering?
interactive rendering means rendering from XSI.exe
- render region
- preview
- render current frame
- render current pass
batch rendering is rendering with xsibatch
- xsibatch -render -scene "\\server\...\something.scn"
// Steve Blair
Re: AD subscription
Post by Daniel Brassard » 14 Nov 2012, 19:07
Thanks Stephen,
So correct me if I'm wrong:
XSI.exe access 4 Satellite machines
Each xsibatch.exe can use up to 4 satellite machines for a total of up to 20 satellite machines
so the NLM give you access to up to 24 Satellite machines for rendering?
1 Interactive machine for rendering
4 satellite for rendering
5 xsibatch for rendering
20 satellite rendering (4 satellite per xsibatch)
Grand total 30 machines can be used for rendering?
Re: AD subscription
Post by xsisupport » 14 Nov 2012, 19:11
Daniel Brassard wrote:Thanks Stephen,
Yeah, but there's only four working on any given frame.
24 if you're in marketing.
// Steve Blair
Re: AD subscription
Post by Daniel Brassard » 14 Nov 2012, 19:16
Got it!
steven07
Re: AD subscription
Post by steven07 » 14 Nov 2012, 19:24
Doesn't Max have unlimited render nodes? I don't know why everyone doesn't just do this :S
This would definitely be a plus for the subscription. I'd get the subscription just for that.
Letterbox
Re: AD subscription
Post by Letterbox » 14 Nov 2012, 20:12
Sblair, since your doing a such great job of SI support by answering all these questions.
I'd suggest, if you're allowed to, and want to, since your now working for Solid-Angle can you say what Arnolds rendering policy is core's/cpu's/batch.
I know it's off topic, but fair's fair you deserve a bit of marketing freedom.
