quickinset
QuickInsetAuthor: Piotrek Marczak
Updated May 2013 (info) — Rewrite of the original QuickExtrude tool. This tool performs quick modo-like interactive extrude, bevel and inset operations without showing a property page. Piotrek's notes from the si-community thread: Extruding along normal is available only in 2012 SAP for operations that relies on SI units you drag in component's normal direction, for other ops (like point skirting ratio/bevel subdivisions) just drag across screen subdivision highlighting is supported only for level 1 and only catmull-clark J, L hotkeys change subdivision on extrude K hotkey is for repeating operation on highlighted component/subselection ENTER shows op PPG shift makes operations 10x slower LMB is extruding, LMB and then RMB - changes inset ratio of extrusion MMB is beveling, , MMB and then RMB - changes bevel subdivisions RMB is insetting tool can also work in supra mode if you hotkey the tool I've used it to model few production objects and it's pretty useful.
Developed with the interactive tool SDK. See Piotrek's video for a quick introduction
local backup: quickextrude_0.2.xsiaddon (June 2013) pmQuickExtrude2012.xsiaddon (older but SI 2012 compatible version) quickextrude_src.rar
Memag
Re: quickinset
Post by Memag » 22 Feb 2012, 17:22
origin wrote:no problem
memag, what's the software you used in this video?
It's called Voidworld (will be renamed to Nvil). Something like Silo,XSi,Max and bunch of other modeling tools in one (although it has disabled animation and painting modules inside, which would be enabled and polished later on).
You can get it here for free(download the last update)...it's still in development but has nice toolset.
But, still clunky at the moments.
Voidworld page
Polycount VW thread
CiaranM
Re: quickinset
Post by CiaranM » 25 Feb 2012, 03:03
Really awesome work. Thanks for sharing!!!
j3st3r
Re: quickinset
Post by j3st3r » 02 Apr 2012, 09:10
Hey,
And how does your "Screen Space Proportional Transform" project progress? :)
This one is very neat, it'd be nice if you release an addon with your Quick* tools.
origin
Re: quickinset
Post by origin » 03 Apr 2012, 21:36
Sorry didn't have free time recently, but I will finish it thats for sure :/
pluMmet
Skype: bigcuberight
Re: quickinset
Post by pluMmet » 04 Apr 2012, 13:48
Falam
Re: quickinset
Post by Falam » 08 Oct 2012, 02:21
origin wrote:Tool was rewritten few times, so please report bugs...
- Extruding along normal is available only in 2012 SAP
- for operations that relies on SI units you drag in component's normal direction, for other ops (like point skirting ratio/bevel subdivisions) just drag across screen
- subdivision highlighting is supported only for level 1 and only catmull-clark
- J, L hotkeys change subdivision on extrude
- K hotkey is for repeating operation on highlighted component/subselection
- ENTER shows op PPG
- shift makes operations 10x slower
- LMB is extruding, LMB and then RMB - changes inset ratio of extrusion
- MMB is beveling, , MMB and then RMB - changes bevel subdivisions
- RMB is insetting
- tool can also work in supra mode if you hotkey the tool
- I've used it to model few production objects and it's pretty useful
Is this the updated keyboard short-cut list for this tool ? I have a question about the "K" tool, when you say repeating, does that mean I can select a new set of polygons and repeat repetitive tasks on another set, similar to a macro action ?
origin
Re: quickinset
Post by origin » 08 Oct 2012, 22:10
Yes as far as i can remember
Falam
Re: quickinset
Post by Falam » 09 Oct 2012, 14:39
Sorry, what I meant was a action, similar to Photoshop. If the polygons are the same, I run the macro and all the extrusions and bevels are done automatically.
origin
Re: quickinset
Post by origin » 14 May 2013, 22:01
Updated 1st post with small patch (File with comment " LATEST" )
-fixed some bugs with selection, multiple objects and others
-removed selecting feature
-tool now will extrude by clicking anywhere in viewport when component selection is not empty
-repeat op key 'k' will work also after re-launching tool, e.g. if you want to repeat bevel on different set of components
-better visual representation of extrusion axis
pluMmet
Skype: bigcuberight
Re: quickinset
Post by pluMmet » 15 May 2013, 00:26
Great tool. Thanks for keeping it up!
Re: quickinset
Post by wireframex » 15 May 2013, 08:04
Thanks for sharing ^:)^
origin
Re: quickinset
Post by origin » 15 May 2013, 17:51
Thanks. Forgot to mention you may need this if plugin won't load http://www.microsoft.com/en-us/download ... x?id=30679
Nox
Re: quickinset
Post by Nox » 10 Aug 2013, 11:51
Great update, selecting feature was annoying, now it works perfectly, thanks!
stevejjd
Re: quickinset
Post by stevejjd » 05 Nov 2018, 10:49
How do I assign a hot key to these tools? Thanks
Legends Never Die
Maximus
Re: quickinset
Post by Maximus » 06 Nov 2018, 10:48
stevejjd wrote: 05 Nov 2018, 10:49 How do I assign a hot key to these tools? Thanks
file > keyboard mapping > on the left column find "custom script commands" then on the right column find "pmQuickExtrude" and drag and drop it to any hotkey you want.
stevejjd
Re: quickinset
Post by stevejjd » 06 Nov 2018, 22:46
Maximus wrote: 06 Nov 2018, 10:48
Thank you so much ~ I found it :D.
I wont let Softimage die - I'm gonna learn it. I love it already. Much better than Max and Maya. I hope someone from Autodesk just steels XSI and leaks it to the world.....that shit should be open source.
Legends Never Die
