ICE Procedural Feather
Procedural Feather
Generates a procedural feather. Includes a number of useful strand-related compounds
that can operate on their own. From the si-community thread: you have to create the curve along Y axis the center of the curve has to be on the first point the pointcloud has to be parented under the curve and to be at 0.0.0 TR ‐ Then
you can transform or deform your curve and the feather will follow.
Video available here. See the thread linked below for all the details.
local backup: FeatherTool.rar
This is something I did recently in my free time .Just having fun with ICE.
Limitation:
-you have to create the curve along Y axis
-the center of the curve has to be on the first point
-the pointcloud has to be parented under the curve and to be at 0.0.0 TR
Then you can transform or deform your curve and the feather will follow.
I am uploading a scene so you can see the setup and also the compounds.
You have to copy "tim_FeatherToll" folder under your workgroup>data>compounds, before you open the example scene.
Download
Feel free to improve it.When I get more free time I may make it better but for now that's it.
Limitation:
Download
Re: ICE Procedural Feather
A very fast way to make a feather. Thanks for sharing
Very cool! Thanks for sharing.
it is a amazing tool ! thx!
Hi, i try to use this compound but i get this error (on both si-2013 & si-2015):
WARNING : 3000-EDIT-AddICECompoundNode - Could not find node : Fill Interpolated Array
Did you tried to contact the author?
Did you dissect the compounds and repair it yourself or is it not loading at all or even crashing?
Tim, an ex colleague and friend of mine, has moved on from ICE and is mostly working as a film effects artist using Houdini at MPC, and also has a young family, so he has little time left to help out here.
Myself on the other hand, am still using SI daily, just dont check in this forum that often, so here is info you need.
If you open the scene file that Tim provided it all works fine in 2015 straightaway and the 'fill interp array' compound is clearly there in the 'Create_ F_Base_Strand' compound. So the error is from how you exported his compound from the scene.
My suggestion is to go back to the provided scene and re-export the master compound 'Tim_Feather_Generator' but make sure you tick the box that says 'embed internal compounds' and you will find that all the missing internal compounds are now included.
a clear user error problem , there is nothing wrong with this compound in 2013 - 2015 whatsoever.
Yes but i'm not much skilled in ICE ;)Pancho wrote:Did you dissect the compounds and repair it yourself or is it not loading at all or even crashing?
It don't make the Base_Strand.
This trick worked now it works properly. Thanks so muchTekano wrote:Tim, an ex colleague and friend of mine, has moved on from ICE and is mostly working as a film effects artist using Houdini at MPC, and also has a young family, so he has little time left to help out here.
Users browsing this forum: Mojeek [Bot] and 71 guests
