need help of how to improve workflow
clankill3r
Post by clankill3r » 08 Jul 2014, 21:44
This topic is related to this topic:
(watching the screenshots should be enough to get an idea)
http://www.si-community.com/community/v ... 697#p45697
In short, i work on a anamorphosis, and i need a flat version of the 3d.
This is what i do now:
To explain, i have a "3d" version and a "flat" version, I use a camera projection to position the image.
Then I freeze the Texture Projection and change the point positions to the one of the flat one so i have a idea how the print would look.
In detail:
1. I copy the ICE tree cause the ICE tree is gone when i freeze the texture projection.
2. Freeze the texture projection
3. Create a new ICE Tree
4. Past the copied ICE tree and connect it (this makes it flat, like a paper to print)
5. Look at the result and press ctrl+z a lot of times to undo all steps.
6. Make some changes and start back at 1.
What i think would be best is have a flat model that takes the texture projection from the 3d model.
This way I never have to freeze the texture projection. Could it be done like that?
NNois
Re: need help of how to improve workflow
Post by NNois » 09 Jul 2014, 03:19
hi,
Are you aware than you can control and create texture projection with ice ? plus projecting from a point use just very simple maths.
The solution for you is simple and use just one object and ice tree with 2 steps
1. create you texture projection from a point (vector)
2. flat you points
but... hey you have other solutions here's somes:
1. use an ice tree to simply copy the texture projection from your deformed object to you flat object (get data .... texture projection uvw -> switch context -> set data self texture projection etc...
2. do the same without ice at all with one object and use a morph (shape key)
etc...
clankill3r
Post by clankill3r » 09 Jul 2014, 12:16
Hey, i'm not good in ICE or softimage at all.
I tried:
since that came the closest to my understanding.
However, my result has a different scale. As can be seen on the attached image.
Why is that?
If it helps I can send the scene file.
NNois
Post by NNois » 09 Jul 2014, 13:36
ok, here is the scene you need a shape where your paper is folded (create the shape then delete the cluster shape combiner)
https://www.dropbox.com/sh/1a2bl66q2rrb ... zUU-QApZqa
clankill3r
Post by clankill3r » 18 Jul 2014, 13:46
Sorry for the late reply.
I tried to open the scene but it says I need to load it from version 1300 so I guess your softimage version is newer.
I tried to recreate it but I don't have the CameraProjection Compound.
Post by FXDude » 18 Jul 2014, 16:10
Hi, sorry but why do you need all that in the first place?
What if you..
- Got a grid,
- set a default flat shape as it is, and then save another shape deformed as desired,
- Created a camera projection on the deformed shape
- and then froze that projection,
then could'nt you mix between between flat/deformed as desired?
