Curve To Ribbon
Curve to RibbonAuthor: Julien Carmagnac
Video demo. Curve to Ribbon generates polygon mesh strips based on input curves. There are settings for subdivision, thickness, center and offset as well as for the ribbon plane: XY, XZ, YZ or auto. Works with multiple curves and even merged curves. Requirement: »keyvis Curve Tools« by Eugen Sares (moved directly below).
local backup: CurveRibbon.xsiaddon
julca
Curve To Ribbon
Post by julca » 21 Jan 2014, 13:38
Hello,
I want share with you my last plugin.
It create ribbons from curves.
I use the offset command from the "keyvis Curve Tools" addon created by Eugen Sares.
It create a perfect base before the loft.
So, you need to have this addon already installed (but who did not ;) ?) if you want use mine.
"Curve To Ribbon" have a custom property witch drive all proxy parameters from the differents meshes/operators.
Quick video demo :
Cheers.
CurveRibbon.rar
(89.76 KiB) Downloaded 636 times
Bullit
Re: Curve To Ribbon
Post by Bullit » 22 Jan 2014, 04:08
Rork
Re: Curve To Ribbon
Post by Rork » 22 Jan 2014, 09:30
He,
That's a neat little tool!
Thanks for sharing, much appreciated! :-bd
EDIT: Just tested it here, but getting python errors and an OLE message. It does create the curves, but no geometry.
SI 2013SP1, installed the .xsiaddon in a server workgroup.
julca
Re: Curve To Ribbon
Post by julca » 22 Jan 2014, 11:44
Thank you guys !
Rork wrote:Just tested it here, but getting python errors and an OLE message. It does create the curves, but no geometry.
I just test it with 2013 SP1 (in a custom workgroup) and it work on my side.
Can you give me your model for a test ?
Rork
Re: Curve To Ribbon
Post by Rork » 22 Jan 2014, 12:23
didn't do anything special. created a sphere and created the curves like in the video.
after that ran your tool.
retried with a couple of restarts of SI as well, same result. I do run the SI internal python thingy btw..
julca
Re: Curve To Ribbon
Post by julca » 22 Jan 2014, 12:27
I also run SI internal Python.
Can you send me your log ?
Rork
Re: Curve To Ribbon
Post by Rork » 22 Jan 2014, 12:42
This is what I get after selecting the extracted curve and running the tool:
Application.SelectObj("crvlist", "", "")
# File "<Script Block 2>", line 43, in curveRibbon_Execute
# firstCheck()
# File "<Script Block 2>", line 358, in firstCheck
# main(collOfCurveSelection)
# File "<Script Block 2>", line 82, in main
# customOffsetCurve(collOfCurveUniqueLeft, gRibbonWith * -0.5, collOfAllOffsetOpLeft)
# File "<Script Block 2>", line 322, in customOffsetCurve
# xsi.ApplyOffsetSubcurves(inCollOfCurveToOffset.GetAsText())
# File "C:\Program Files\Autodesk\Softimage 2013 SP1\Application\python\Lib\site-packages\win32comext\axscript\client\pyscript.py", line 142, in __getattr__
# return getattr(self._scriptItem_.dispatchContainer,attr)
# File "C:\Program Files\Autodesk\Softimage 2013 SP1\Application\python\Lib\site-packages\win32com\client\dynamic.py", line 500, in __getattr__
# raise AttributeError, "%s.%s" % (self._username_, attr)
# AttributeError: Application.ApplyOffsetSubcurves
# - [line 321 in \\SERVER\xsiwg\Tools\Addons\CurveRibbon\Application\Plugins\curveRibbon.py]
# ERROR : OLE error 0x80020101
Application.curveRibbon()
hope that helps,
julca
Re: Curve To Ribbon
Post by julca » 22 Jan 2014, 12:52
It's seems that you don't have the "keyvis Curve Tools" addon installed.
Can you check this ?
Rork
Re: Curve To Ribbon
Post by Rork » 22 Jan 2014, 13:01
Ah... that makes sense.
I misread your comment on the Keyvis Curve Tool. I was under the impression you used that part of the code.
But you use the plugin as well to get to this.
Problem solved! ;)
julca
Re: Curve To Ribbon
Post by julca » 22 Jan 2014, 13:11
Cool !
I use my own extract subcurves code but use the "ApplyOffsetSubcurves" command from the "keyvis Curve Tools" addon.
leo3d
Re: Curve To Ribbon
Post by leo3d » 23 Jan 2014, 13:02
Excellent Julien :-bd :-bd
leo
julca
Re: Curve To Ribbon
Post by julca » 23 Jan 2014, 17:12
thank you Leo !
druitre
Re: Curve To Ribbon
Post by druitre » 20 May 2016, 12:43
thanks Julca, this one saved my ass today
- Jasper
julca
Re: Curve To Ribbon
Post by julca » 20 May 2016, 13:37
druitre wrote:thanks Julca, this one saved my ass today
- Jasper
Cool ! I am very pleased that this serve you well ! :)
And coincidence, I have used it again this morning.
RoN43
Re: Curve To Ribbon
Post by RoN43 » 27 Apr 2017, 13:47
Thanks!!
julca
Re: Curve To Ribbon
Post by julca » 27 Apr 2017, 15:49
RoN43 wrote:Thanks!!
I am glad that this is useful :) .
