Maybe I have being on this too long that I cannot see the forest for the tree anyway
say you have this array {-6,0,1,3,-5,0,-2,7,0,-10,2}
You want to be able to find all the negative numbers in this array and return the index value. The answer in this case {0, 4, 6, 9}
I tried the "find in array" node but it can only take a value, nor "if" or "lower than" node as input.
I would like to avoid the repeat node if possible. Thanks for the help!
Selecting values in array
- Daniel Brassard
Re: Selecting values in array
Hahaha, I love it. Such a simple yet awesome solution.
- Daniel Brassard
Thank you IamVFX,
Like Chris_TC said, simple but elegant. It never occured to me to feed the second port.
Dan
Dan
- Daniel Brassard
With this simple trick, I was able to do this:
Test if a point is inside, on the surface or outside. The first step toward the marching cube or marching tetra!
Now that sounds promising! Keep goingDaniel Brassard wrote:The first step toward the marching cube or marching tetra!
Nice one, so usefull... I was stuck on my problem untill I found this topic.
Here how I used your trick:
I was making some tracks on the ground on the path of a snake.
Let's say the ground is hit by the snake at each frame. Each points receive a boolean data "touch" when they are touched for the first time. At each frame I also create a scalar data called "DisplacementY", which is the current Y distance to the initial Y position. Afterwards I create a "get nearby points".
Here was my problem: get the average "DisplacementY" of the nearby points using the already touched points only.
I use the index array in "find in array" to remove this array from the other array...
Many thanks again!
Many thanks again!
Now, with recent Reinhard's found, you can do it without Find in Array node
[rimg=1100]http://i.imgur.com/WpRrDy9.png[/rimg]
Users browsing this forum: trendiction [Bot] and 31 guests
