PolyMesh Duplicator v1.2.1
PolyMesh Duplicator
V1.2.1 Nassos' recreation of Guillaume Laforge's addon (see video). Creates multiple procedural copies of a mesh which can be accessed from an ICE
tree. Just like Houdini's Copy/Duplicate SOP. See video tutorial on vimeo, and for more details see the si-community discussion link.
Re: PolyMesh Duplicator v1.1
And BTW,
my apologies for the messy C++ source.
i dont understand how this work...
i have SI 2010 x64 SP1
Following your vimeo tutorial.
After install i open a new fresh scene, create cube -> Polygon MEsh - > polymesh duplicator, then i get an error wich is this:
' VERBOSE : ApplyPolyMeshDuplicator_Execute called
' ERROR : 2028-EDIT-AddICECompoundNode - Invalid argument specified. - [line 97 in C:\Users\Max\Autodesk\Softimage_2010_SP1\Addons\PolyMeshDuplicator\Application\Plugins\ApplyPolyMeshDuplicator.vbs]
' ERROR : 2028-CUST-ApplyPolyMeshDuplicator - Invalid argument specified.
Then i check the explorer, and i found Cube and cube_copies wich has "PolyMeshDuplicator" under modeling construction mode. I click that open it up and change the values from 1 to anything else and they dont duplicate, nothing happens.
No idea whats wrong.. i installed the last one you posted, this one:
PolyMeshDuplicator Addon v1.2.1.rar [61.33 KiB]
Can help me please ?
Thanks a lot for your patience
Restart XSI after installing the Addon. Then it will find the new compounds.Maximus wrote: ' VERBOSE : ApplyPolyMeshDuplicator_Execute called
did that, i do the same thing as before and nothing happens
No idea whats wrong
No idea whats wrong
when changing the scripts i "cut & pasted" instead of "copying & pasting" some parts
my mistake.
redownload from here please
my mistake.
- PolyMeshDuplicator Addon v1.2.1.rar
- (61.39 KiB) Downloaded 2038 times
thanks!!!! works perfect!
- wireframex
Hi
I can't install this script maybe it is not compatible with 7.01 x64 ?
Phil
Phil
What do you mean you can't install?
Does it give you an error?
Does it's icon in the Plugin Manager have a red triangle?
Does it install and does nothing?
Does it crash 7.01?
What???
Does it crash 7.01?
What???
- wireframex
Sorry,
There is the message from XSI :
The plugin is not compatible with the current platform ...
PolymeshDuplicator installed from Install Add-On menu
XSI 7.01 x64
windows 7 Ultimate x64
RAM 8 Go
Phil
XSI 7.01 x64
RAM 8 Go
Phil
This is weird, since i compiled it with the 7.01 x64 libraries.
on my winxp 64 machine it works fine.
I repacked the addon from inside 7.01 x64
if it still doesn't work
i rar'ed the folder structure of the addon
so just decompress it in your "Addons"
user directory under the name "PolyMeshDuplicator"
and either restart XSI or manually load it.
- PolyMeshDuplicator 1.2.1 - packaged with 7.01.rar
- (40.54 KiB) Downloaded 227 times
- PolyMeshDuplicator 1.2.1 - 7.01 Folders.rar
- (29.6 KiB) Downloaded 236 times
- wireframex
Thanks a lot for your super fast answer.
well same pb here for the 2 solutions :
I have this message :
ERROR : 2360 - This plug-in is not compatible with the current platform and will be ignored:
<path: C:\Users\xxxxxxxx\Softimage\XSI_7.01\Addons\PolyMeshDuplicator\Application\Plugins\PolyMeshDuplicator.x86.dll>
seems it only wants a x64 dll ?
Phil
Phil
the x86 version is not supposed to be compatible with the x64 edition
it is for 32bit XSI.
It should automatically ignore it
well just delete the "PolymeshDuplicator.x86.dll" file
and leave the "PolymeshDuplicator.x64.dll"
- wireframex
Now it works
Thanks a lot
Phil
EDIT : Maybe you need to try to detect typical version of XSI because PolymeshDuplicator.xsiaddon doesn't install for me because of the x32.dll
EDIT2 : Or just do 2 versions of your script x32 and x64
Thanks a lot
Phil
Because if it didn't install you wouldn't get the following error:
which is ok BTW.
XSI is supposed to ignore one of the two ".dll"s and continue loading the other one.
Correct me if i am wrong, but i have the suspicion that you didn't even try the command
after the error msg appeared.
Do the following :
Uninstall the addon,
re-install it,
the error msg will appear (as expected)
create a cube (or whatever primitive)
try the "Modify->Poly. Mesh->PolyMesh Duplicator" command
and tell me if it works.
- wireframex
In fact it did'nt works at all, if I want to use it it tells me :
Unspecified failure
Unspecified failure
could you post the whole line of the error?
it usually prints the line number of the file where it encountered the error
Users browsing this forum: Yandex [Bot] and 39 guests
