Motion Tools 1.0
Motion Tools 1.1
Project moved to GitHub in Jul 2017 --- Motion Tools is a small collection of tools that aims to aid Motion Graphic work being
created inside Softimage. The idea is to create a workflow for the creation, distribution
and animation of instances as intuitive as the ones found in comercial solutions.
Since it is created ontop of ICE the tools have speed and combustibility considerably
superior to similar solutions.
Demo video available here. For demos of the previous beta versions, see here vor v0.1, here for v0.2 and here for v0.3.
local backup:motiontools.zip
author site: http://gustavoeb.com.br / download: /mtools / author @ vimeo / project @ github / si-community thread
Motion Tools 1.1
Updated September 2012 to support polygon island pivots/rotation fixes. Motion Tools is a small collection of tools that aims to aid Motion Graphic work being
local backup: motiontools.zip
Motion Tools 1.0
Hey guys!
As of today I'm releasing the first non-beta version of Motion Tools. (which is a small collection of tools that aims to aid Motion Graphic work being created inside Softimage)
I'm finally happy with features and stability, and have addressed the lack of documentation and samples.
You can download the 2012 and 2013 versions and sample scenes at http://www.gustavoeb.com.br/mtools. You will also find the documentation, tutorials and a little spot to report bugs there...
Ill leave you with a video introduction better explaining what this is and how it works.
Ps: It is always valuable to highlight this started here in our Community Projects
Gustavo Eggert Boehs
Re: Motion Tools 1.0
Thanks! I look forward to making something cool with your compound sometime soon.
Si Community has it's first baby.
Very nice seeing this tool coming to a 1.0
thanks a ton for sharing this, and showing people the power of ICE.
kudos!
kudos!
Come a long way since then
Thanks for keeping at it. A lot of good ideas in there!
- TwinSnakes007
Thanks so much for this. I'll be using this in my testing of the Mitsuba exporter. Its gonna be super-easy to setup particle test scenes now.
Thanks again.
-TS-
Well this is amazing, really great work, thanks a lot for this.
Didnt expect to find some rbd stuff, the falling text was one of the example i saw on Momentum demo scenes, really nice to see it here.
Thanks again!
Max
Thanks again!
Max
Yehh ! thanks a lot gustavo for this very great set of tools
Just very curious after seeing your great video presentation, does you simulate stuff permits now motion blur on particles ?????
have you managed motion blur working on non simulated ice trees
Thanks,
Noël
Thanks,
Noël
Good question, and the answer issssss... on simulations Yes. No for the rest. Simulations have a PointVelocity attribute that enables MR to render MB.NNois wrote:Just very curious after seeing your great video presentation, does you simulate stuff permits now motion blur on particles ?????
have you managed motion blur working on non simulated ice trees.
The hacks Ive investigated to fix this are ugly and non-intuitive and, therefore I have not implemented them. Arnold and 3Delight can render this just fine. MR implementation should just do the same, in my opinion (at least have the option to do so)...
This is a good time to put this up the priority list and find a decent workaround for the time being... thanks for bumping on this
I've noticed that the motion blur works even if the ICETREE is set under the modeling stack, so not simulated. but to see the effect you have to increase the speed a lot. Not sure if its the correct thing to do tho.
edit, actually nvm it doesnt work on particles, i was using the geometry
- Daniel Brassard
Good work Gustavoeb, very nice tool, i'm glad you finished it.
Post us some images when you do ;)
As an ex Cinema 4D user I find this great cause I have missed Mograph module:) Thank you Gustavoeb.
Thanks a lot, also for the tutorial video and documentation, much appreciated!
- bottleofram
This has come long way. I applaud your effort, Gustavo.
