It is currently 19 Jun 2013, 13:58
Post new topic Reply to topic  [ 121 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13  Next
 Post subject: Re: PhysX Fluid Simulation in Softimage ICE
PostPosted: 25 Jun 2012, 21:37
No problem Oleg, I'm just enthusiastic :)
Good luck with Implosia update!
PostPosted: 11 Jul 2012, 10:41
my problem is solved after install softimage 2013 , now it works fine .
i think its best solution to simulate fluid in xsi . i hope u release new version of this soon.
thank u so much Mr.Core
PostPosted: 21 Jul 2012, 19:02
Hi all,
here is the updated version, based on physx 3.2, so it supports now nvidia kepler GPUs ( tested on my GTX670 and fermi-based GT520 as well ), also added ability to delete particles.
As declared in the final 3.2 SDK version there is added support for triangle( actual ) shape for kinematic ( animated ) obstacles, but it still doesn't work and nvidia's devforum doesn't work as well (see here ), so I will ask why once they will restore it
The attached archive contains 4 DLLs, which you need to put in "C:\Program Files\Autodesk\Softimage 2012/3 XXX\Application\bin" and the physx workgroup which you need to connect through File->Plug-in Manager->Workgroups page->connect, after that you MUST restart xsi. This also needs to be installed ( if you have si2013 skip this step since it already has installed this package).
If the wg has been installed successfully, in the same archive is placed xsi project with the sample scenes.
If you find some bugs please report here or via gbotfx gmail.com :)
PostPosted: 22 Jul 2012, 14:44
Thanks!!
(It's working on my 670, I'll go and test it out some during the week)
-Jasper
PostPosted: 13 Aug 2012, 19:46
I'm not being able to use concave dynamic obstacles, is there a way to make them work or should i separate those objects into convex pieces manually?
Another question, can you enable a mode where the particles are just treated as rigid bodies with friction?
I say this to do granular simulations like sand because i think the physx tigid bodies included in SI does not work with the GPU, and this is a lot faster than the GPU, i've never seen 1 million particles being simulated so fast!
Cheers and thanks for this, it's amazing!
PostPosted: 14 Aug 2012, 00:09
I dont now why, but physx still unable to use concave obstacles, when I add any mesh marked as concave ( trainlge ) px just ignores it. As I can judge from the physx SDK improvements list support of concave kinematic(obstacle) meshes has been added since third beta, but it doesnt work yet.
And nvidia's dev forum also is down.
It is impossible due to particle's nature, it represented as non-material point in space, not as solid rigid body and thus provides very high speed on solving. You can try to set zero viscosity, high stiffnes and both frictions to achieve more "sandy" look.
thanks for feedback,
-Oleg
PostPosted: 14 Aug 2012, 00:32
this looks like a lot of fun, sorry I havnt had time yet to have a go with the new version Oleg, soon I hope!
PostPosted: 14 Aug 2012, 15:21
Thanks for this great implementation!
Is it possible to do self collision with eg a box shaped particle?
Christian
Arnold for the masses!
PostPosted: 17 Aug 2012, 22:53
You can easily build an array of topology with cube primitive shape and drive it by particles and "transform topo" node :)
It really looks amazing! And there are also a couple videos with their RD on GPU cloth with long constraints - also very impressive stuff and I hope they will add it soon
PostPosted: 24 Aug 2012, 21:16
Hi Mr. Core,
Just want you to know what a great plugin this is.
I have one issue though:
I have an nVidia Quadro 600 and a nVida Tesla C2075
As far as I can tell, I should be able to see CUDA, but this error seems to suggest that the plugin
can't see a CUDA card.
Is that what it means? It seems to run fine without the GPU button checked, but as soon as
I check it (or press play on a scene where it is set to use GPU, such as your demo scenes) I get this error.
Maybe I have to update a driver or something?
Any help would be most appreciated!
Perry
Users browsing this forum: No registered users and 4 guests
