It is currently 20 May 2013, 17:15
Post new topic Reply to topic  [ 10 posts ]
 Post subject: custom materials on get>materials list
PostPosted: 26 May 2012, 21:48
Hey guys, i was wondering if anyone know a method to add a custom material to the default menù in Softimage, "Get> material" list.
Tryin in all the ways i could think of but no success. This would be handy :)
Thanks a lot
Max
 Post subject: Re: custom materials on get>materials list
PostPosted: 26 May 2012, 22:57
If I recall correctly (can't check right now):
Quote:
Create a Preset of the Material node
Create a Custom Command using the Wizard
In this Wizard set the menu option to "siMenuTbGetMaterialID"
Generate Code
In the Custom Command Definition use Application.ApplyShader to apply the preset.
Save Command
I do hope I've recalled this correctly :-s
Broken, not stirred...
PostPosted: 27 May 2012, 11:32
Still tinkering with your material presets I assume? ;)
Photography & Video Reference/Tracking Cubes - http://www.refcube.biz | Softimage tutorials blog: http://www.rowu-media.nl/rwmblog/category/tutorials
PostPosted: 27 May 2012, 14:01
I'm studying metals and found a way to achieve them in a realistic way (ala maxwell), wanted to add those in the menù, but still a bit of time before they are ready.
Generate Code
Save Command
Tryin to figure out what this all means! i suck when it comes to coding and strings :)
PostPosted: 27 May 2012, 19:51
I admit it was an attempt at a very concise description of the procedure...
If you don't understand parts of it, feel free to ask for further explanation, obviously... ;)
PostPosted: 14 Jun 2012, 14:20
Hey Hirazi, i followed your procedure but it is not working.
How it can read where the preset it stored? You said first to save a preset of the shader i want in the menù. But i save it in a precise folder.
Now what is the command or how can i make it read that particular shader?
I'm a bit confused.
Also "In the Custom Command Definition use Application.ApplyShader to apply the preset." dont get where to put this.
If you could explain a little bit more i would appreciate it :)
thanks
PostPosted: 14 Jun 2012, 17:47
While rechecking this I noticed something is amiss. Probably the fact, but I'm guessing here, that ApplyShader isn't the right command to begin with (seems to only work with Factory presets, but I will probably be mistaken, as I am under stress, see next sentence). Must investigate, but my PC just crashed: I will get back to you!
:-s
edit: When writing the previous instructions,
I probably just modified a factory preset, with which it worked...
:ymblushing:
PS It appears LoadPreset is a safer bet. I've sent you a PM
PostPosted: 15 Jun 2012, 08:09
Alrigh, i managed to add the shader to the menù, and it works fine, the only weird thing that happens is once i apply it to an object it pops up the Phong PPG instead of its own PPG. Anyone have any clue how to solve this?
Here is the code i used. It works and it applies the shader, but it pops up wrong PPg.
Code:
# mia_material
# Initial code generated by Softimage SDK Wizard
# Executed Fri Jun 15 03:26:17 UTC+0200 2012 by Max
# Tip: To add a command to this plug-in, right-click in the
# script editor and choose Tools > Add Command.
import win32com.client
from win32com.client import constants
null = None
false = 0
true = 1
def XSILoadPlugin( in_reg ):
   in_reg.Author = "Max"
   in_reg.Name = "mia_material"
   in_reg.Major = 1
   in_reg.Minor = 0
   in_reg.RegisterCommand("Mia_Material","Mia_Material")
   in_reg.RegisterMenu(constants.siMenuTbGetMaterialID,"Mia_Material_Menu",false,false)
   #RegistrationInsertionPoint - do not remove this line
   return true
def XSIUnloadPlugin( in_reg ):
   strPluginName = in_reg.Name
   Application.LogMessage(str(strPluginName) + str(" has been unloaded."),constants.siVerbose)
   return true
def Mia_Material_Init( in_ctxt ):
   oCmd = in_ctxt.Source
   oCmd.Description = ""
   oCmd.ReturnValue = true
   return true
def Mia_Material_Execute(  ):
   Application.LogMessage("Mia_Material_Execute called",constants.siVerbose)
   Application.ApplyShader("", "", "", "", "siLetLocalMaterialsOverlap")
   sel = Application.Selection(0).Material
   Application.LoadPreset("C:\\Users\\Max\\Autodesk\\Softimage_2013\\Data\\DSPresets\\Shaders\\Material\\mental images\\mia_Material.Preset", str(sel))
   return true
def Mia_Material_Menu_Init( in_ctxt ):
   oMenu = in_ctxt.Source
   oMenu.AddCommandItem("Mia_Material","Mia_Material")
   return true
Thanks everyone, and thx Hirazi
PostPosted: 15 Jun 2012, 10:32
At the beginning of your "Mia_Material_Execute" code block try adding the following line:
Code:
Application.SetValue("preferences.Interaction.autoinspect", false, null)
This however should suppress all PPGs, so if you would want to a PPG for the specific new Preset you'd probably have to do an InspectObj on it specifically...
Belated edit: add this additional line (after the "LoadPreset" line),
that should suffice to inspect the suppressed PPG again:
Code:
Application.InspectObj(sel)
PostPosted: 16 Jun 2012, 10:20
thanks a lot Hirazi, that worked perfect!
