xPOP3
XPOP v3.2
Updated Oct 2016 with a Houdini rewrite by Julien Carmagnac. XPOP Menus popup menus that are fully customizable via scripts, and can be used
with all scripting languages available in Softimage / Houdini
New features for XPOP 3.2: Underlined items Some new icons Icon caching Greyed out menu items Icon support (including Checkmark) Icon collection from axialis.com included Object oriented API (similar to Patrick Boucher's python extension for XPOP2) Section headers for more linear grouping than submenus Visual customization options: margins, spacing, font, fontsize, coloring
Julien's brand new XPOP for Houdini is available here. Junkie's japanese version of the documentation is available here..
local backup: XPOP32.xsiaddon (drag-and-drop)
author link: http://rray.de/xsi/xpop/ / si-community thread
xPOP3
XPOP Popup Menus
V3.0 for Softimage 2011 SP1+ Win32/64/ Linux(?)
example for an xpop menu
New Features for XPOP V3.0
Icons (including Checkmark)
Icon collection included (from Axialis Team)
Function/Attribute reference and download @http://si-community.com/download/lb/rray/xpop/
Re: xPOP3
I'm loving the current activity around XSI. This addition looks very nice and can prove to be quiet helpful. Thanks!
- Zafar Iqbal
Re: xPOP3
Re: xPOP3
Why did I think of Facebook and not Flipbook when I saw the "F" icon? I dissapoint myself
The updated site is better imo.
- Zafar Iqbal
Re: xPOP3
I though of facebook first too, I think it's because of the font for the f they used
Thanks for your comments!
Re: xPOP3
On the xPOP3 website you mention "Axialis Studio" twice, without further explanation (as far as I can tell).
Linking to the accompanying website might be a good idea to let everyone know what you're talking about...
Re: xPOP3
My bad --- you're right, thanks for the note --- fixed. Their name isn't even Axialis Studio, it's Axialis Team xD
- eternal art
Re: xPOP3
I have Xpop menu in vbscript and want to add more than one line of code to the one of my menu item without make a command for it ?
example :
this code will import my obj , i want to do many other things beside this import to the same menu item .
i hope my quesion is clear enough .
example :
Set item = popup.AddItem ("Dragon", "ObjImport Application.InstallationPath( siUserPath ) & ""\Addons\XSI-Shelfy\Data\Obj\Dragon.obj"", 1, 0, False, False , False, False" )
Re: xPOP3
You have two options, either use a subroutine or function defined in the same file where you build the menu, and call that in the string, or you can put several commands inside the string and separate them with a ":"
- eternal art
Re: xPOP3
Hi ..
Is there anyway to add a header and separator to the sub-menu ? or it's not supported , also it's nice if we can " Tear the menu " like softimage menu (Considere it a feature request ;) ) .
Thanks in advanced .
Sorry i forget to thanks you for the answer , it's what i want .rray wrote:You have two options, either use a subroutine or function defined in the same file where you build the menu, and call that in the string, or you can put several commands inside the string and separate them with a ":"
Re: xPOP3
AddHeader and AddSeparator should work fine in submenus,
pinning the menu would require a complete rewrite, the windows TrackPopupmenu function which I'm using doesn't support this.
Btw, here's a newer version of xpop that caches icons-- menus with many icons display much quicker.
- XPOP31.zip
- (127.34 KiB) Downloaded 369 times
Re: xPOP3
Another little update, this one adds underlined sub menus/menu items (Thick underlines Softimage-Style, if you'd like to tweak the underline style, it's being drawn in lines 258-263 in XPOP32Plugin.py). Also adds some new icons for boolean operations (intersection, difference...)
Build your underlined menus using
item = xxxxyyy.AddItem....
item.underlined = true
item.underlinecolor = 0xFF0000
Share your custom menus !
Ray
DL: docs: http://rray.de/xsi/xpop/
Ray
Re: xPOP3
Hello rray,
I'm writing a popup menu script using XPOP3.2.
I want to use my own icons.
But "LoadIcon" method does not seem to work.
It returns a error saying "no such method/property supported." (in Japanese. See the pic)
(SetIcon method works fine BTW.)
Do you have any idea?
Thank you.
Thank you.
Re: xPOP3
Hello Junki!
My mistake - I forgot to add LoadIcon as a public method, please go to XPOP30Plugin.py and edit line 18 from this:
_public_methods_ = ['SetIcon', 'EnableItem']
to this:
_public_methods_ = ['SetIcon', 'LoadIcon', 'EnableItem']
That should do it
-rr
to this:
That should do it
-rr
- sirdavid32
Re: xPOP3
Hi team. I recently added a video on how to install this. Instructions were pretty straight forward, and I'm thinking on creating a custom .addon to distribute a custom Xpop menu.
Web: http://www.3dcinetv.com
